Two Station VHF
orboater
Looking to purchase a two station VHF radio.
Any recomendations as to brand and/or features I should be looking at.
Would like intercom and hailer as second station will be located at flybridge.
I have a Uniden MC900-90 channel with remote at the bridge. Has proven to be an excellent unit.I can't tell you about service because I've never had a problem with it. Going on 8 years now.
Originally posted by orboater
I like the Standard units. The radio goes below. You have a 2nd wired microphone with all the controls on the flybridge. There's two types, those with the built in hailer and those without. So, the microphones are different.
When you're done with the boat, the microphone unplugs and you secure the receptical with a weather cap.
I think you will want to find a remote mic that has some volume to it. Sometimes it's hard hear the remote microphone speakers while underway.
I am currently using the Raymarine 240 with remote head and speaker. I also have a Uniden 625 with the WAM4 wireless mikes. The Uniden will be for sale with 3 remotes (wireless) as soon as I get the new Garmin NEMA2000 200 VHF radio with wired remote to be released mid-June.
The Simrads are great but quite pricey. I have the older Shipmate RS8300 handsets w/ remote speakers and prefer them 100% over the conventional permanant mounts or "command-mics". So much easier to understand incoming traffic at cruise in the tower or below near the engines.
Thanks to all that replied. I now have more research to do with the Brands/Models suggested.
Have taken boat out a couple of times and really feel uncomfortable without VHF on bridge.
This is what I have; came with the boat and haven't seen any reason to step up. Practical Sailor recently top rated it.
http://www.boatfix.com/shop4/store/viewItem.asp?idProduct=3873
Up on the bridge I have one of these, which gives you all the controls (volume is for its own speaker only), great unit:
http://www.boatfix.com/shop4/store/viewItem.asp?idProduct=1581
I use an Icom M88 as my second unit down stairs, and a SH Quest as the second up stairs; we go through areas with a lot of bridges and/or traffic on other channels (like 13 or 14) and I like having two radios for those situations. This equipment get used a lot as we move the boat up and down the east coast from the Keys to Massachusetts.
George
Hatteras 56MY
currently at Barefoot Landing, Myrtle Beach. Off to Wrightsville Beach, NC in a little while.
George
Hatteras 56MY
How is the volume on the mic speaker? or do you have a external speaker hooked up to it?
I'll put in my two cents and say buy two separate radios. Back-up is good. Radios are not that expensive. I had a minor problem with my pilothouse radio, but it was a just when I needed it most. I was glad I could readily switch to the upper helm. I also have two or three hand-helds for the same reason.
Ditto. Very good point. I also carry 2 hand helds as backup. Redundancy on a boat is a really good thing when it comes to safety.
i agree, dont' really see the point of 2 station units... not really cheaper than 2 separate VHFs and that will give you the most redundancy. I would even go as far as feeding them from different battery banks.
Well, the reason you do it is the reason I did it (add the RAM mic upstairs): This way I have two separate radios at each helm. If the Quest accepted a RAM mic, I would put one downstairs. It doesn't , so I use the ICOM for that purpose.
The functionality of the RAM is great; nice big display too. I use it as the main radio when upstairs. And yes, the speaker is plenty loud.
George
Hatteras 56MY
decided to stop in lovely Southport NC this pretty Carolina spring day.
There is a very good argument for two completely separate radios, both with remote mikes. Just two separate radios doesn't give the redundancy and dual channel monitering capability (the dual watch/scan is not really adequate). Many of the radios with remote mikes/hailers can be also used as an intercom. Both Icom and Standard Horizon are excellent radios and both companies make commercial grade communication equiptment.
I do have the existing unit at the helm, plan on leaving it there.
The hailer and intercom are looking good to me also.
Have had Standards before and they have worked well. I'm leaning in that direction.
I've got a similar setup as George with a Standard Horizon radio below decks and a RAM mic at the help station (on my little boat that means the RAM mic is 3 feet behind the radio!). I actually think the speaker in the RAM is better than that on the radio. It was a good purchase and it fit my needs perfectly.
As for the dual radio suggestions, I agree with that as well. I keep another SH handheld in a charging base at the helm station as well.
Just put the order in at Boatfix.com.
Ordered th SH MATRIX GX3000S with the remote mike and a hailer horn.
Thanks to all for input.!!
