The 'angle" that is being measured in degrees as you read on the specs for the transducer is actually called the "Cone Angle".
If you picture the sonar signal being sent out by your transducer as an upside ice cream cone you will understand better what is happening.
The larger the angle of degree (higher number) the wider your signal is being spread, but less dense in concentration. As you go into progressively deeper water, you are "painting" a larger area of the ocean bottom with your signal.
A narrower or smaller cone angle is preferred when you are fishing frequently in the deep, while a wider (smaller number) is better for less deeper water. There are some transducers that are designed to work in waters like the flats down in the South east coast or the Bahamas, etc.
As far as thru hull versus transom mount? The answer is that the thru hull "SHOULD" work better. In regard to your particular boat, your mileage may vary!
A
"PROPERLY LOCATED AND MOUNTED" through hull will work better than a
"PROPERLY LOCATED AND INSTALLED" transom mount. This is only because the through hull is located in the smoothest and "acoustically cleanest" water which is further away from the prop(s) than a transom mount.
Every boat differs, so while one boat may work better with a thru hull, another boat may work better with a transom mount. Much has to do with the hull characteristics of the boat, and whether an upstream fitting, chine or strake cause some turbulence.
Transom mounts are not the easiest to mount as the actual position of the transducer face has to be "just so" or you will not get the ultimate echo, or will lose image at speed, or will get 'lost bottom' symptoms.
By design, a transom mount is meant to "snap" out of the holding bracket if an obstruction is hit, to avoid damage. Many transom mounts have a tendency to "shift" slightly, or pop up completely, particularly in sloppy conditions, and cause the boater to have to reset or shift them, usually at an inopportune time.
If you are concerned about putting a hole in the bottom of your boat, remember that the manufacturer has already put a handful in there!
The accidents that you hear about with failed thru hull transducers are usually the result of sudden hard impact or a poor install.
There is a newer type of transducer available, manufactured by AIRMAR, that is called a "tilted element" transducer. These are mounted in a hole in the bottom of the boat like a conventional thru hull, but are flush to the hull surface and protrude by about 3/16". they are next to impossible to knock loose by impact or by putting on a trailer. There is just really nothing to hit. The install, by following the instructions, can be done by a Saturday DIY'er with some simple tools and materials.
THEY NEED NO FAIRING BLOCK!
The sending element is tilted, and the assembly can be tweaked to match the deadrise in your hull so that the transducer face is always as close to perpendicular to the ocean bottom, the ideal position. And they run clean and turbulence free. A coating with transducer paint and they remain clean for a full season.
They are available in two configurations, 12 deg. and 20 deg. to more closely match the deadrise of the boat. There is also a HIGH Performance model available in SS with multi elements and 1000 watt capability for the serious offshore fishermen.
I have two fish finders on my boat. The same 2010C as yourself, and a Furuno NAVNET. While there is no comparing the two, I use the Garmin as a backup, or, as the primary, when I need to run radar on the Furuno. I originally had a conventional bronze thru hull with fairing block hooked up to the Furuno; with a shoot thru (as mentioned in another reply) to the Garmin.
I switched out the Furuno tranducer, and installed a tilted element. I no longer lose image at any speed, or in sloppy conditions. The overall image, definition and separation is much better with the tilted element!
I am considering switching out the shoot thru and installing another tilted element for the Garmin. A friend of mine did that last year and saw much better results with the thru hull hooked up to the Garmin. He did this on a relatively thin hulled flats boat, so he never really had much signal loss with the thru hull which is their major disadvantage.
No matter what fish finder you may purchase, no matter how much it costs or how many bells and whistles it has, the extent of its performance and your satisfaction is dependent on the transducer. A poor install or the wrong type can make a superior Fish finder a mediocre performer, while a good install with the right transducer can make a mediocre fish finder a dependable producer!
http://www.airmartechnology.com/airmar2005/ex20/RMProducts/ElectCat.asp?ProdID=36&Man=Garmin&PageNo=67
Hope this helps.
