Underwater lighting???
jdshep
I am having two 35 watt Xenon bulb under water lights installed on transom. The lights are US made by Aqua Lights link http://66.49.199.208/bronze.htm
They also make underwater camera's at very reasonable prices. The lights I picked are http://66.49.199.208/Specs/AL35X-Bronze.pdf
The 35X units on this chart http://66.49.199.208/beamcomparisonchart.pdf
I have seen this lighting on other boats and I was blown away by the effect. The water we boat in is very clear so you get to a lot of fish when you have the lights on.
The Marina offered smaller lights of a different brand that cost a little more, these lights i think will do the job at a little savings. I plan on switching them right at the transom inside of a locker. Does anyone have a different idea? Marina was going to run it to helm, but I see no reason to do that as use should be a dock and at the cockpit.
I did search BoatFix before I went elsewhere looking for lights, I found none. Boatfix is my first choice for all my boating needs, but I guess that don't carry these yet.
John d:
Met a couple with them on their Flemming 55. They had them switched from the cockpit originally. They'd occasionally leave them on and with the short bulb life they were replacing them frequently. They had an electrician move the switch to the main panel with an indicator light. They have to pass the panel on the way to the main cabin at night so it wasn't a problem to just flick it off on the way to bed. Way cool though! :o)
That sounds like a good reason to have the switch in a location where I will see they are on. The bulb on the lights i picked is said to last 6000 hours, but even with that long life i sill only want them on now and then.
John d
I think there's were some high powered xenon thingies with a 600 hr life. Think he said they'd light up to 100' down or something like that.
John,
I have almost the same lights.... ITs very cool . My switch is at the dash.
If I could id add a third.... ( one in the middle ) but they give off a ton of light ull be very happy .... that is as long as ur not boating in pea soup
Single 150 HID 115v from deepsea lights on a 360 Dancer.
I added a switch inside the cabinet below the cockpit sink.
Three years and counting and I leave it on often.
The HID has great bulb life.
Waaay Cool
Jim Conroy
I installed Aqua-Lights on my Four Winns, really cool if water is clear. Swithch should be on instrument panel with indicator light because in dirty water you can't tell if they are on or not.
Originally posted by Robski97
John,
The water by us is clear and you can see bottom in 15 to 20 feet of water. I dropped a line at Mackinaw Island and it sank to the bottom. I put a 16 foot pole together had no trouble seeing line, but lacked skill to grab it with my shaky pole. A boat hook would have done the trick.
John d
I'm looking into led's. Seem to last alot longer than HID'S and the cost is coming way down. There are many manufacturers out there.
LEds are good reliable .. no way as bright ( clear white ) as the xenon.
Since were all doing it for effect and are drilling a hole in the transom.... Break the bank get the bang for ur buck and u wont be disappointed...
Last thing u want when ur all done is I should........
Rob,
Have you looked at the Ocean LED lights yet.
As bright or brighter than 35 or 50 watt Xenons.
Jonathan
Two 150w HID lights from Deep Sea Power & Light...
Jonathon,
Buddy has same boat as I and he has the LEDS.... There are so many different brands and tag lines its difficult to keep straight. So in a side by side comparison mine were WHITER ... and Brighter... LEDS are rated differently .. Some I saw said COMPARABLE to ... or BRIGHTER THEN...
To me thats B/s advertising stuff.. LIKE 100 % better ... ( 100% better then what? ) So do ur home work before u spend the $$ to much money to do it twice.
I just raft up to someone that has them ;-)
Jonathon,
What brand does youor buddy have Rob?
Jonathan
