Underwater video camera
HarlenW
Anyone know of a low cost underwater video camera to occasionally inspect the props, rudders and hull of the boat? Black and white would be fine.
Thanks.
Are you looking for something remote controlled or hand held?
HERE is something pretty cheap. Unless you have a very big boat 17' depth should be good.
George
G,
Thats just the housing, Harlen would still need a camera. Pretty cool anyway
George, That's just a casing that you put your Sony Handy Cam into to make it waterproof.
They sell waterproof inspection cameras
Depends what you consider low cost as most U/C video cams range from "somewhat pricey" to a lot more. I use an Atlantis B&W system w/100' cable that has proven to be very handy many times for checking U/W running gear, locating various items on the sea bottom including anchors and fish, and inspecting the bottom of the engine and hidden bilge areas. http://www.atlantiscamera.com/product-pages/AUW-502.html
Presently there are at least 3 Atlantis U/W cam systems listed on ebay so you might check there with an "Atlantic camera " search.
The one I use was generously donated by my B.I.L., so I consider that very low cost. Perhaps you have a BIL who is as into electronic gadgets?? Having used this one occasionally for many years, If I were get another one I would definitely get the color panning camera system and contact Atlantis to see if I could get it with a longer cable. Even drifting in calm water it si difficult to aim the non-panning type in any but 1 of up, down fwd or back directions. For running gear inspection , I tape it to a 6' curved length of semi-hard 1" plastic tubing and can manuever that fairly well.
For your stated use, you might be able to purchase just the B&W cam & cable & perhaps figure a way to hook it up to a portable DC TV/monitor/ laptop screen or compatible chartplotter. If you can get a low cost computer cam with a long enough cord you could probably figure a way to bag & effectively seal for shallow depth waterproofing.
Sandy
Just looked at DonB's HF link. That appears to be the most affordable model of Atlantis' U/W video cam systems at a very good price.
That is what I get for not reading carefully.
G
Thanks, Sandy, that is exactly what I had in mind.
