Used Monterey
dljdad
I still own my beloved and trusted Bayliner 1952, but we'removing on up. I have found what looks to be a (no survey yet, will do so if we proceed) great buy on a 1991 28' Monterey. It has twin 4.3s and VP duoprops.Is anyone familiar with Montereys? While I realise 91s have carbs, is this still a fairly good setup? Being an old hotrodder, 4.3s have a great land rep..how about boats?
__________________
Robin's Nest
Willapa Harbor
Dave,
Not sure about the Montereys...but the volvos and the duoprop have been good to me. Don't forget to get the boat surveyed.
Montys are built in north central Florida, so this one's far away from home! There are a lot of them around here and people are happy with them. Be sure to survey everything. Not just Hull + Engines + Drives. Check electrical, etc. too.
I am familiar with Montereys from the factory to the dealer, to many other owners.
Am the proud owner of a 98 262. .
Lo maint--if there is such a thing for a boat--Equipped with 454 MPI w Bravo III
I have a 1996 276 model. We have had it since 1998; just this year we are moving up. We were very happy with the boat. It is a 454 with the BIII so it got up nicely and cruised at about 28-30MPH. You'll like it.
My Sea Ray 290 Sundancer has twin 4.3's. Boat weights around 8,500 lbs empty. When I purchased the boat used seven years ago, I was told that the boat is underpowered. After using it for 6 seasons I would have to say that larger engines would have been better. If you're looking for some serious speed - over 25mph, then the 4.3s will be too small. My boating is in the North Atlantic, so we never had the need to go much faster. However, if you're a lake boater, you may want more power. BTW, we have Alpha I drives on it - don't know if that makes a difference or not....
I am very happy with the 4.3 inboards in my 29' Silverton. Not a hot rod but I don't want my boat for that purpose. I enjoy the trip more than the destination so taking longer to arrive is fine by me.
I bought a used 2001 Monterey 282 express with twin 5.0 Volvo w/DuoProps last year. So far the boat's been great and after much research am comfortable that that power package was the way to go. Volvo has an excellent rep. As for Monterey, the boat appears well built (time will tell) and I found it a great value over similar age/size SeaRays. The Montery owners forum thru the factory is weak but the factory has been quick to answer mine and other questions that are posted.
I too would be concenred wiith the carbed 4.3's underpowering the boat. I had a 28' Wellcraft Martinique with Alpha 1's, and had to run the thing HARD to stay on plane.
