using 3 year old gas
Mike Wood
I'm removing 3 year old gas form the inboard tanks. I have tried some in a mower and ATV, both ran fine, so I put about 12 gals in my son's car (which is always on “E"). No ill effects after a couple of days of driving around.
The gas smells like good gas but has a slight yellow tint to it. I thought after 3 years it would be varnish. I guess I'm concerned that even if I do a 50/50 with fresh gas in the vehicles that it can mess up something.
I know dumb question, If it works it works but, has anyone had a bad experience using old gas? I have about 160 gals.
thanks
Mike, there has been several post about this in the engines forum. As long as there is not water in the fuel, a 50/50 mix with 93 octane should work. I personally would rather run it in a automobile, problems on the road are different than problems on the water.
Ken
Thanks Ken, I'm removing the tanks from the boat and would like to use the gas instead of having to pay to haul it away. I'll check out the engine forum
As I mentioned in another post, I've got a buddy who has 3 year old gas in his boat and he added 10 gallons of racing gas to his tank (110 octane). Seems to be running fine.
Way before the gas shortage in the 70's we used to have a tank at the farm filled with gas. It sat for years and we thought it was empty. One day I pumped it to see if there was any gas in it and I got about 5 gallons. It was at least 5 years old at that time, so I put it in a lawnmower and it ran. I put the rest of the 5 gallons in a 1968 Rambler and had no ill effects. Granted, that was different technology in both the engine and the gas, but I don't see that it would cause any problems. The only bad thing is that it's lower in octane. I'd mix it with some fresh fuel and you will be fine.
I have 3 year old gas in a boat that I'm running. No problem as long as some stabilizer was added. Another thing, the nore gas there is, the longer it takes to go bad.
If it smells like good gas, it is probably good. I have had gas that was in a 5 gal. tank for a year and it did not smell like gas at all.
I used it to burn some ant hills and some old stumps and it didn't burn as well as good gas.
Now THAT sounds like something I'd do! We used to pour it down sage rat holes on the farm. We'd wait for a while, light it and RUN! You'd get a WHOOOOSH when it caught and you'd hear squeals down the holes as the sage rats scurried out some other hole! It was either that or a shotgun! Flames were a LOT more fun!
add some octane improver but no new gas and run easy until the tank is as close to bottom as you dare.
Back in 1991, I bought a '67 Lincoln for $250, as a project car. It had been off the road since 1973. The next year, I drained 10 gallons of 18 year old gas from the tank and ran it in my lawnmower and my old Chevy van with no ill effects. It was yellow like apple juice and smelled bad but worked fine.
As noted above, old gas is quite usable, but save it for a land vehicle and dilute it with fresh gas.
Yes, but, BlueMonday, that gas formula was very different from that of four or five years ago and far different from today's formulas. Your results may differ!
I pumped out about 35 gallons of 5 year old gas out of my 100 gallon tank. It looked and smelled OK. I tried some in my lawnmower, it was OK,so I tried some in my 1995 escort, it ran OK, them some in my 2005 mustang, and it ran OK.
I was worried at first but it seemed to run OK in all vechicles.
I had about 20 gallons left in the tank so I put 20 gallons of premium in it and the boat ran fine.
Hey I just had a thought, I saved about $137.00 dollars. I remember when I put the gas in 5 years ago it was 1.99 a gallon.
After I eat Mexican food, I often have a problem with "bad gas"
I don't know Hogan? Always seems to be a difference of opinion between the Gas-ee and Gas-or!
Thanks to all, i'm using the gas without issues.
