Using a Windlass for the first time
airbus
The boat I recently purchased has a windlass, which is new to me.
The other day while I was out, and after reading the manual, I thought I'd experiment a little.
As I was letting the chain out, it worked well until it got to the rope, oops I mean rode, then it hung up at that point. It appears the connection between the chain and rope will not fit thru the windlass hardware.
Any ideas? Am I doing something wrong.
Isn't it supposed to let the rope/rode out as well?
hard to reply if you dont' even tell us what kind of windlass you have !!!
some can handle chain and lines, others can't. usually, the line has to be spliced into the chain for the connection to go thru smootly...
sometimes you need to keep a little tension for line to pay out smoothly, especially when the line ages and gets a little stiff.
Perhaps the line has a kink in it. Sometimes, if it doesn't coil itself properly in the locker, when you go to let it out, it'll snag.
Airbus,
To answer your question, yes, the windlass should work with rope and chain rode.
Let me repeat this back to you.
You take the safety lanyard off the anchor (you have one, right)
You turn on the power to the windlass.
You press the down button. As you do this the windlass turns and pays out the chain portion of the rode.
At a given point the chain ends and the rode transitions to a rope. At the point where the rode goes from chain to rope there is not a big granny not, however at the transition there is a few inches where the rope is larger.
At this point the windlass stops moving even though you are still pressing the down button.
My first question is this. Is the rope from the windlass motor back to the locker loose or tight?
To me is sounds like you have a knot in the rope portion of the rode inside in the anchor locker.
Lets start with looking at this first then go from there.
Originally posted by Presentationrentals
Airbus,
Granny knot? How do we know what the transition is from anchor rode to the line? Are you already familiar with Airbus and know what the transition looks like?
FWIW- I just saw this happen with a friend's windlass when the line portion of the rode with being pulled up. It caught at the transition area, then the windlass pulled it in on itself really hard. We had to disassemble the windlass to free the snag. In that case, there was too little tension on the rode. It shouldn't happen on a regular basis, but I know it will happen again, unless he's right up there feeding the windlass. My recommendation was for him to just bite the bullet and have an all-chain rode. That way, if he is ever alone at the helm, he can raise the anchor without worry.
Paul
Airbus, I have a Lewmar windlass and experience this issue on occasion going up and down. Typically you will need to make sure of two things.
One make sure that the rope is tight, in other words no slack, on mine you rech into the anchor locker and hold the line tightly down so that when the windlass gips there is no "bunching " or slack in the line.
Second if it is Lewmar design make sure the cap is tight. Mine loosens and as it does the windlass cannot grip the line, even eventually will not grip the chain and this can be very dangerous while trying to anchor or trying to lift the anchor.
Maybe neither but that s where I've seen the issue on my Silverton.
Airbus,
I sometimes run into the same problem during rode retrieval. The windlass has a hard time passing that section of the rope/chain connection because it is fairly stiff and bulky. When paying out the line there is usually enaough pull/weight on the rode to keep it from hanging up there. I have found that soaking the rope ia bucket fof fresh water with some Downy fabric softener will soften the rode enough so that it now passes thru this restricted area of the windlass.
Wow,
Thanks everyone for all the quick replies. I'll take a look at the connection between the chain / rode tonight when I go back down to the lake.
I didn't know you had to put tension on the rode, but that make sense, so if the connection looks ok, I'll try that.
The windlass is a Lofrans. Not sure about the model #.
Airbus,
Thanks for the advice. Yes, I do have a safety lanyard.
Be classy, get rid of the Granny and clevis.
Get a Fid, a Bronze or Stainless sleeve and make a permanant Rode/Chain splice. Thin, without obstruction, will pass through just about anything the Rode will pass through.
Once you've learned to do that splice, you can do it in a minute or two.
Unlike knots or Clevis, those splices never fail.
nibbs...
maybe you haven't spent much time trying to help others here and aswering questions, but how can anyone expect a reply on a technical issue if they don't tell us what they are using ! for all we know, he may be trying to get a shackle thru a chain only windlass...
hey... my engine doesn't start, where do i start ? :-)
nibbs...
Sorry,
Until a week ago I had never even seen a windlass. I wasn't even sure how to ask the question.
I think I'm on the right track now.
Thanks everyone.
nibbs...
With responses like yours, people will stop asking questions!
Oh, contrare Mr. Nibbs, the gentleman you are bustin' on happens to be very helpful and for my two cents worth, makes it more inviting to participate in this forum. Too much coffee today?
TGCZAR
TGCZAR
+1
Paul
airbus... no need to say sorry !
another thing in addition to what's been mentioned (splicing and tension) is to make sure the rode isn't kinked in the locker. if that's the case, try to spread it on the dock, of even trailing it in the water when anchored in a current and work the kinks out.
there is nothing more frustrating than your rode jamming when you really need it to pay out smoothly !
I had a maxwell on my previous boat and the transition was often a problem even though it was spliced in.
also, if your locker is to shallow, the rode may not self stow without help... not much you can do if that's the case but help it out...
My windlass is old enough that it is a "free-falling" which can only handle chain OR line, but not both. So I've rigged 6 ft of chain around a capstan and only the line goes through the windlass. As a result, my anchor does not free fall very well and I have to be at the bow to pull it through and around the capstan. I usually pull until the anchor & chain are well settled on the bottom, then return to the helm to complete the anchoring process.
When I am retrieving my anchor, I drive the boat up onto the anchor as I am reeling in the rode from the helm. I've only had a problem one time when my line was very twisted and formed a "knot" which would not go through the windlass. I pulled it up by hand [and my back!] to get back to the slip. Then I added a swivel [exactly like those used in fishing tackle, but bigger]. When I'm reeling in the anchor, I let the line untwist after the anchor breaks the water, then I complete reeling in the line/chain, etc. I've never had a twist in the line ever since.
Bottom line, it depends what type of windlass you have, not just the brand. Your instruction manual will clue you in. Looking for terms such as "free falling", "combination chain/line", "vertical" and/or "horizontal" to give us a better idea how to help you.
Good luck and enjoy your new boat!
Airbus, sorry about this - I realize this may hyjack your thread, again I apoligize. I have been boating for 20+ years. I would call myself a diehard and consider myself to have alot of experience. I joined this and 2 other boating forums to continue to educate myself and to offer my experiences to others. I have to say, I am just about ready to give up on this site. There are very few here who actually offer constructive advice. The rest of you simply are rude, offensive and have no consideration for others time. I'm a good sport and appreciate a laugh just as much as the next guy. There are areas on this forum for play. But some of you jump on any chance you can to slam someone. I do not know Pascal personally, but it is so obvious he is here to help and offer his vast backround of nautical knowledge. This is not about Pascal, just using him as an example.
I know that if I do not like it here I can leave. Not much bothers me and I could care less what anyone does. I have just had it with all the bull and knit picking - Sorry. I guess some hear have nothing better to do.
Airbus, If I had some comments worth voicing I would. The truth is I have never had a problem with my rode / windlass yet. But becasue of your post, I am going to inspect my chain to rode connection carefully. Thank you for possibly preventing a problem for me.
Not totally on topic (as it relates to the splice), but relevant for some of the posters:
My boat has a shallow style rode locker, causing lots of headaches during anchoring and retrieval. I even tried all-chain, but still had trouble with the chain not having enough room to fall and unload. Recently changed to, and had complete success with a line called "8-plait" - professionally rigged (braided) to 30' chain.
· 8-Plaited nylon rope eliminates some of the service problems associated with the 3-strand ropes. 8-Plait uses 8-individual braided strands woven together that allow the rope to be relaxed. But, when under load, it tightens up to a firm lay. The higher the load the harder the lay becomes.
· 8-Plait carries the same tensile strength as 3-Strand.
· 8-Plait does not coil or create a "birds nest" in the locker like 3-Strand will. 8-Plait flakes and falls upon itself.
· 8-Plait will not twist and knot up.
· 8-Plait will not loop over onto itself.
· 8-Plait has less stretch so it will not bury itself deep into the gypsy's grip when overloaded, which means less damage to the stripper when the windlass is abused or overloaded.
· 8-Plait pays off of the windlass into the locker much like chain, allowing for better use of smaller locker designs.
· 8-Plait is 80% less prone to becoming stiff when used in salt water than 3-Strand.
· 8-Plait nylon rope is 1/3 more absorbent than 3-Strand rope. More absorbent means more weight; more weight means better fall into the anchor locker.
· 8-Plait should be soaked in water (salt or fresh - it does not matter) to pre-lubricate the rope so it can be used in the windlass initially. When rope is used dry and new, we have seen either slippage or sticking in the rope pocket of the gypsy. Once the rope is wet and used, it out performs the 3-Strand. The longer it is used the better it gets.
