5000 series.All was running ok to haul out last fall.Removing prop this happened With prop shaft unhooked,I can rotate transmission output shaft 2 to 5 turns then locks up.Rotate it back 1/8 inch or less then rotates fine.Can do this either direction.Fluid levels o.k. no filings ever when changing fluid.Approx.850 hours.
