Vinyl Cleaning Help
pgilbert
You know those fold up chairs that are made of fabric that you stick into a bag for storage? Well I put a couple of them on my vinyl seats overnight and the red dye from the covers got into the vinyl.
I tried all the various vinyl cleaners and restorers I have at the boat. They got some of the color out but still some remains. Anyone have any thoughts on how to get thes rest out??
Did you try the Magic Erasers? Also, I've had success with Scrubbing Bubbles on vinyl. Spray on the area and let it sit for a couple of minutes. It bubbles away to lift the dirt/stain out of the creases of the vinyl. Or try wetting the area and sprinkling Bon Ami over the stain. Let it sit for a bit. Then rinse off.
Let us know how you get it off!
I know OxyClean is made more for natural stains such as grass, blood, food stains, etc., but I wonder if Liz's suggestion using OxyClean instead of Bon Ami might help.
Hello,
Yes, with a "dye" stain, I would try OXY Clean.
Often stains on vinyl will tend to fade out over time, but if yours persists as many do, you might try fixing the same way it got stained. Auto parts stores and some hardwares sell cans of spray vinyl dye in white and other colors for just this purpose.
If you think of going this route , definitely try the spray on a discardable piece of vinyl or in a spot that can't normally be seen to see if it produces an effect desirable to you. The only "professional" re-dyeing job I inspected on someone else's boat did not look very impressive to me so I ended up opting to replace, but I think in some circumstances the dye could work pretty well.
I had a similar problem from a dark canvas cover staining white vinyl seats. Nothing worked. I tried all the cleaners mentioned above. They made the stain lighter but would not remove it. Use some softs scrub with bleach to remove any protectant then leave the vinyl exposed to bright sun for a week. I bet the stain will be bleached out. Mine disappeared completely. After that clean it with a good vinyl cleaner and a brush and then apply a good vinyl protectant like 303. If you had a good coat of 303 on there, the chairs may not have stained it.
I applied 303 to my seats and somone got ball point pen ink on them. The ink came right off with spit. Usually ball point pen ink is one of the hardest stains to remove.
I would try the sun before using any more harsh cleaners or attempting to re-dye or paint the vinyl.
If all else fails, acetone will take it off. Obviously an extreme measure but if you follow it up with a vinyl treatment you are probably fine. I have used acetone and then a vinyl treatment with no adverse effects.
i'm with michaelnj. give it a resonable cleaning then let the sun at it. save the harsh cleansers for the bathroom.
Hey MichaelNJ,
What is "303", is it like "Armour All"?
Where do you buy it?
TJ
Amazing Roller Off is the best vinyl cleaner I have found. Once you clean the vinyl do not forgot to protect it with 303.
303 is along the lines of Armor All but much better. 303 is actually a line of products www.303products.com The protectant is called "303 Aerospace Protectant" It provides UV protection. You can get it at any place they sell boat supplies and some auto stores. They also have waterproofing and stain guard spray for fabrics like sunbrella.
I've used hairspray on pen ink also. It's pretty good.
Serious Marine Cleaner by Yacht Brite worked wonders for me and the whole boat.
[:-captain]
