Volvo Drive question
glenncal1
Hey Guys-On my new to me Volvo SP outdrive there is a drain hole below the water intakes. Not the oil drain hole. When I run the boat on the hose lots of water goes out that hole and I get much better waterflow through the engine if I stick my finger over the hole. Is that hole supposed to be open or is there a freeze plug or something that should be there. The Volvo we site doesn't show anything. Thanks
That hole is supposed to be there. Possibly a drain to prevent freeze damage?
Or possibly to keep water flowing if slots are plugged with debris?
I'm not sure but it is there.....
john
If it's on the bottom of the gear case at the leading edge of the skeg, It's my understanding that it's a relief to keep the water pressure from getting too high at speed. (It also makes sense that it's there to make sure that the case drains for the winter...)
