Waste Pump?
Ikhanton
I have a 2000 Commodore 2460. On the 12V side of the electric panel there is a switch for Waste Pump. And when I turn it on I hear a pump but I do not know what it does.
I have been on other Regals but their switch states a Macerator pump, so I do not believe that is what I got.
Can someone tell me what this Waste pump switch does and how I am suppose to use it for?
Thank you in advance for any help you can provide.
I have the same switch on my 2465, but wasn't connected to anything. In the engine room , behind the batteries a found two "cut wires". It appeared to be those for a macerator (found the other end of the wires behind the 12V/115V panel. I installed a waste pump early this year.
Check around your waste tank, you could find a macerator and in this case don't forget to open your through hull valve before setting your Waste switch to ON.
Nice pics Joel.
Please keep in mind you must be in an area that allows for overboard discharge which in the United States is 3 miles or more off the coastline. I don't believe there are any inland places where you can legally discharge any more.
Yes Rommer, I know that but here in France there is not such legislation (up to now...). But believe me, I don't use my waste pump when not far away from coasts.
And here you can see the wires I talked about :
According the Regal Owners Manual, the brown with black stripe wire is for the macerator.
So, to understand what you all are saying; on my 2000 2460 the waste pump is the "macerator."
If that is so, and I here it running when I turn on the switch, where is the sea cock that opens up?
I suspect it is somewhere in the engine room. Do you trailer your boat? If so the next time it is on the trailer look underneath for any openings. That could give you a clue where to look.
An AC thru hull has a scoop type pickup. A generator and macerator will usually be just a opening.
Hope that helps.
Definately NOT in the Great Lakes.. We have a switch for a Macerator, but no Macerator exists - and since we can't use them here, no sense to install or have one.
Or have a swim and look for something like this:
And in your engine room something looking like this (normaly with a hose connected...) :
Are you the original owner?
If not, maybe the original owner hooked that switch up to something else. I always thought that switch was for the shower pump. Then my float switch got stuck and the switch wouldn't stop the pump. That was when I discovered the switch was not connected to anything. I later connected it to a new 12 VDC accessory outlet in the cabin.
Also have a fuse for a "tank monitor". Thought it would let me know when the waste tank was full. It was also not connected to anything.
Oh, and nice pictures, Nouchka.
I noticed that you keep the anchor light in the engine compartment. Don't you find it a pain in the arse to get it out? Engine access has been my biggest complaint in the 2465.
I have never used the table stored in there. I just bring up the cabin table when we need it.
Cosmo Knot,
I have also a "tank monitor" fuse connected to...nothing. There isn't any tank monitoring system installed on my 2465. I fill up the water tank everytime I leave the dock and have a look at the waste tank when I check the engine oil level before starting the engine.
The waste pump switch was free of any connection when I looked at it initialy. Then I found the cutted "brown/black" wire in the engine room and investigate to find its utility...Result: to power a macerator. So I installed it last May.
I prefer to store the anchor light in the engine compartment (its original storage place) because of the 'softness' of the aluminium tube. Could get easely dammaged if placed elsewhere (aft berth for instance). And , as we don't need it every day (night)...not a big deal to retrieve it once in a while by opening the engine hatch.
I don't have a cokcpit table (as you do I just take the cabin table). Maybe the weight of the cockpit table, stored below the engine hatch, makes it more difficult to open the hatch. If you don't use it , why don't you remove it?
The 'history' of my boat is quite strange. Initialy bought in Florida (by Intercoastal Marine), then sent to France as a present for the daughter of the original owner. The electrical system was in 115V... (battery charger, water heather, air conditioning, electric stove, microwave...). As we have here 220V this was useless and the AC system had to be changed by the seller to be put according 'european standards'. The boat had only 40 engine hours, almost brant new when I bought it in 2005.
The good point of this is that the electric stove had been replaced by a butane one, so Admiral can cook even when on the hook somewhere... and that all this equipment in completly new.
It's not the weight of the table since the hatch has gas-charged pistons to lift it up. It's having to move the cushions, the rear seat (and all the stuff under it), take out the carpet and THEN lift the hatch...
Must be nice to have air conditioning! Too bad you have to give up a lot of storage space for it, though.
Here are some pics of our 2465:
http://regal2465.info/midres/
I only remove the starboard cushion (the one with a "comma" form...), unlock the carpet snaps and roll the carpet a bit , then lift the hatch. It's enough to reach the anchor light. As I haven't stuff underneath the rear seat it's easy ;)
Thanks for your pictures. Very interesting to see other's Ragal 2465. Very clean and shining! Congratulation.
