Watch Hill Adapter
Need to add, that most of the slips are 50A 125 not 250, hence the name “Watch Hill Adaptor”. So a twin 30 or a single 30 will need a 50/125 single or twin adaptor. However there are some slips on D dock that are 50/250. I know Rob, John and others have those slip #’s memorized.
Any idea if they've made any wider slips this year at Watch Hill?
Hoping to get there Memorial Day WE.
I have an adapter so I can use my 30amp cord if a 50/250 is not available.
I always thought a good " Watch Hill " adaptor would be a " Y " adaptor of.... 1-50A/125V ( male ) to 2-30A/125V ( female )....so you can run 2- 30 amp cords to the boat.....just IMHO.
The adapters were still available for rent last season. They were about $7.00 a day.
That Marinco 110A on ebay looks like a pretty good deal. I bought a new one on line a few months back for about $100. I watched ebay for several months before I ordered a new one and a 110A never came up.
I happen to have a 50/125 to 2 30amp Y adapter. I just use one 30amp leg since my boat can take one 50/250 or one 30. I had the adapter from the last boat. I gave the buyer the 50/250 Y with the boat and kept this one in case I ever needed it.
This will be my first trip to Watch Hill but I can tell you that in 6 years, I never encountered a marina with 50/125 service.
Mark,
Welcome to the national park service . They even made watchwill reinstall this b/s when they renovated the docks .
I be there is a week or two. So ill fill u guys in on whats up...
Don,
I have a 2 30amp to 1 30amp adapter that I use when I get to a marina that can't give me 2 30amp outlets. Then I have a 30 amp to 50 amp adapter. When I go to Watch Hill, I use both adapters to get from 2 30 amps to 1 50 amp. So I sort of have what you say, but my setup is more flexible. I have had to use the 30 amp splitter. Sometimes marinas, such as Champlains, can't get you 2 outlets! It works fine as long as I don't run too many things at once. I usually have to shut off the A/C to run the microwave.
Dave......That works.....just one extra adaptor to carry that way. The Y adaptor that Mark has is the way to go.....for Watch Hill. If you split it at the( 50A ) power tower...you can run 2- 30A cords to the boat....you shouldn't have to juggle things.. If you split it at the boat.........you can only run 1- 30A cord....your limited.
"....your limited."
Three inches will defintely limit you, at least that is what I have heard. :)
Walter, tell us about the "Cherry Grove Adaptor" that you have.
Sounds crazy, but the 50/125 was what was there last year. I'm not sure, but I think Sailor's Haven might be the same.
I actually bought two adapters a few months ago. The Marinco 110A for trips to Fire Island, and a 117A for trips to Tobay. Tobay has a good amount of 30 Amp slips, but they also have lots of 50 amp slips too.
Hopefully this year I'll be covered all around.
Don,
I don't split at the boat. I was told that is bad to try and run 50 amp thru a 30 amp cord. I run my two 30 amp cords to the dock, then I use my Y adapter to go to 1 30amp, then I use my 30amp to 50amp adapter to the pole. So I have 2 adapters plugged into each other. If I have 1 30amp socket at the pole, then I don't need the 30amp to 50amp adapter. It is not limited, it is flexible!
Mike,
The Cherry Grove adapter is a zipper on the rear of your boat shorts!!
And yes, Sailor's Haven is 50amp service too.
Hoping to get there this year. Have not been there in 4 years!
A zipper???? that could really HURT!!!
Or getting caught in the zipper!
C'mon admit it, it happens to everyone......once!
Well, maybe not Walter, you gotta get out past the zipper for it to happen!
