water in engine
h2o-oo
I have been breaking starter bolts, I think I traced it to a water problem, I removed the spark plugs and found rust on a couple of them. Any thoughts on how to avoid this in the future. Boat is A 2000 Fourwinns Horizon 180 with a 3.0 liter Volvo-Penta, supposely it does not have exhaust flap for back pressure.
Keep the boat on a lift. Sounds like a design problem. Keep weight out of the stern. be sure that the risers are above the water line. In one case I put a large gate valve on a generator which occasionally went below the waterline under certain sea conditions. The flaps may or may not help.
But you really need to check out the engine, and be sure that there is no serious damage. Get oil analysis to start with (assuming that there is no water in the oil. Then pull valve covers and check the valves. Do compression checks also.
Keeps the piston rings from rusting. Helps the cylinders to prevent rust until you get in there and fix it.
When you replace the bolts, are you using a high quality grade 8 bolt? I find it a little surprising that the starter would have so much torque that it would shear its mounting bolts instead of just stalling. When you replace the bolts, does the engine start up right away, or do you need to pull the plugs to get the water out?
If you are using the cheap bolts from the hardware store then I am not at all surprised that they don't hold up.
Rod
Actually there where #10 bolts, now they are back to #8. It did start right up, there was no sign of water in cylinder only rust on new plugs.Volvo-Penta and dealer said under load. pulling skiers/tubers, I am probally pulling water in the exhaust when I slow down, fix: add riser to exhuast elbow so that is where I am know.
Fornuately the starter bolts only break instead of the engine siezing.
