Originally posted by Bob J
Originally posted by Robyns Nest
Be careful with Whink. Strong stuff, use it quickly and sparingly if you do go that route, Wipe it off quickly and keep rinsing with water on the windows and the boat while applying.
Whink works the easiest. Apply with sponge, rub it around & hose it off. I keep hose running w/o nozzle on it to flood rinse area I've done. I do small areas at a time. If left on too long it will etch the glass; it contains Hydroflouric Acid which is used to etch glass. It is an excellent rust remover as well. Keep off aluminum surfaces.
