Water tank
tcap1
Ok, give me your ideas on cleaning water tanks. New,(to me boat) did not put antifreeze in the tank / water heater and won't. 40 GAL tank plus heater.
Not really looking at drinking, but definetly cleaning dishes & washing.
Tom
Use regular bleach. Put in one gallon, fill with water, turn on all faucets (one at a time) until all water is gone. Fill with water again, flush again. Ready to go. Be sure to get the chlorinated water into all faucets and shower. Going to be doing this myself in about a week ( I have a 33 gallon tank).
I would do the same, except I would put the bleach in, fill with water, just run the water until it comes out, do this on every faucet, shut it off, let sit for a while. Then run it all out, refill.
ONE GALLON?!!! That's way too much bleach for 40 gallon tank. You can 'disinfect' a 200' deep well with 1 gallon of bleach. Below is a typical procedure. Hope this is okay to put on here.
From Peggy Hall (“The Head Mistress”), author of “Get Rid of Boat Odors”
A guide to Marine Sanitation Systems and Other Sources of Aggravation and Odor.
http://shop.sailboatowners.com/detai...=400&group=327
Turn water heater off at the breaker before beginning. Do not turn it on again until entire recommissioning is complete.
1. Prepare a chlorine solution using one gallon of water and 1/2 cup Clorox or Purex household bleach (5% sodium Hypochlorine solution ). With tank empty, pour chlorine solution into tank. Use one gallon of solution for each 5 gallons of tank capacity, which results in 4 Ounces of bleach for 10 gallons of water.
2. Complete filling of tank with fresh water. Turn on every faucet and allow water to run until what's coming out smells strongly of bleach.
3. Turn off faucets--but do NOT turn off the pump...it must remain on to keep the system pressurized so that the solution remains in the lines. Allow to stand for at least 3 hours, but no longer than 24 hours.
4. Drain the tank through every faucet.
5. Refill tank with clean fresh water and drain again through every faucet.
6. To remove excess chlorine taste or odor which might remain, prepare a solution of one quart white vinegar to five gallons water and allow this solution to agitate in tank for several days by vehicle motion (iow, go sailing and tack a lot).
7. Drain tank again through every faucet, and refill with potable water.
One gallon is what I always use and never get an odor from the tank or the taps. I don't drink the water, only use it as a fresh water washdown, and washing my hands or showering salt water off sometimes. I believe tcap1 said not for drinking. Just for cleaning.
**edit...Peggy does have a better solution than mine, but I will keep doing what I have been doing. I do let it slosh around for a day or two at the mooring.
Remember that bleach is highly corrosive to metals and some types of plastics can take on a permanent "bleach" smell/taste. I think less is better. I like Peggy's way. Better safe then sorry!
Yes, I agree Flutterby, that was my point...I didn't mean to come across too strong, but I'd be concerned for the components in my water system using that much bleach. Many plastics will become brittle and metals will corode when concentrations get too high. If less will kill the nasties and not harm my system (or at least less chance of it), that's what I want.
Yep, less is more. I'll give it a try, i can always do it again or add more.
Anyone ever try the stuff at the store, not sure the name.
I usually use vinegar or baking soda for the reasons detailed above. One time I had a really bad case of mold in my water system due to contaminated dock water, so I used vodka. It worked great!
Flutter - I've heard of the Vodka trick but have not tried it for the following reasons:
Afraid it will turn sugary if somehow not removed sufficiently
Costs considerably more than bleach...don't see the advantage
Most importantly - It's alcohol...how dare you waste it!!!
I have an 80 gallon tank and have been cleaning it with 1 1/2 cups of bleach each year then following the above procedure. Never had a problem.
Jeff, sorry to inflame your sensibilities regarding vodka! I can't drink the stuff myself without getting a terrible headache, so I don't consider it a waste.
I added one 1.75 liter of vodka to my 14 gal water tank and flushed it through the system over a couple of weeks. I would let the vodka/water mixture sit in the pipes and tank over the week. Then run it through and add more water, etc. etc. After awhile no more black junk was showing up and after more flushings, I couldn't smell the vodka anymore! It has remained clean ever since. I haul fresh water to the boat for drinking, cooking and making coffee.........
Peggy Hall's recipe (posted by JeffR above) has a math error. It says...
- solution has one gallon of water and 1/2 cup of bleach. (1/2 cup = 4oz)
- one gallon of solution to 5 gallons of tank capacity
- results in 4oz bleach for 10 gallons of water
The result will actually be 4oz bleach to 5 gallons of water. Is this too much bleach?
4 onces of bleach in five gallons of water is not very much....don't drink it
'I can't drink the stuff myself without getting a terrible headache'...the voice of experience:)
Liz, Jeff and I were thinking of using the Vodka as an alternative fuel...you make us sound like lushes. [:-angel]
I use the bleach solution as well. Also, found there was a lot of crud still in the bottom of the tanks, so I drained down to about 1", removed the top access and used a shop vac to suck out the remaining crud.
We drink our water, make ice, shower...all from the water tank. Every fall I do a very good job of cleaning the ice maker and put it away dry and spotless. I drain the tank and that's about it. In the spring, I put about 5 gallons of water in the tank and follow the directions on the Aquafresh label. Essentially you double the amount of chemical in the water tank. I turn on the ice machine and make ice for two or three days and throw it away. I flush the head and run the cold water in the galley, head, cockpit wet bar and shower. After three days I refill the tank with clean water and flush that through all the systems and throw away another batch of ice. After that we drink it and use it for everything else. Our only rule is the tank gets used every week and is refilled with fresh clean water. We have friends who would never think of drinking from the tank, but they do it all the time when on our boat and never know it.
You wouldn't drink the water at Bethel Island! It has a terrible taste and sometimes a smell like rotten eggs [remember chemistry class?]. I don't drink the water in the area restaurants either....same source. Now the water meets minimum state standards, but it doesn't meet my standards!
Jeff/Stan.......if the shoe fits.........enjoy your vodka!
Was supposed to clean the tanks after work But the weather was looking good so took a little cruise instead. Really have to clean the bottom, she really didn't want to move.
I'll get to the tank tomorrow - weather permitting.
Plenty of sanitizing methods to choose from as given. For future winterizing look for potable water antifreeze at in the RV section of Wallyworld or a RV supply store.
