Water Tester?
Doc
Is there something I can stick down in my orange 6 gallon portable outboard tank to see if there is any water on the bottom? I would like to test for water each time I start the motor.
I don't know if the tank has a small leak for rain to come in (it sits in the dinghy on top of the boat) or if it is an Ethonal problem.
I got some water in the 15hp Yamaha's carb and the tech said that it won't all come out when running. I had put in some sticky crap called esorb or something and it gummed it up so bad that I had to get the carb cleaned.
There is paste that you smear on a stick that will turn color (pink, I think) when it gets water on it. Have no idea what the name is.
Yes,
When I was in high school, I pumped gas as a job. There is a paste that I would have to put on the end of a 'stick' that I would use to 'stick the tanks' to see how gas was in them. The paste would turn a different color if water was present.
Go to maybe an auto parts store, or an oil/gas dealer and see if they will give you/sell you this paste.
Look up SAR-GEL or Kolor Kut water indicating pastes, and get one for use in gasahol. Any local plumbing supply should have this stuff. For a 6 gallon tank you are better off just tipping it slightly and siphoning off a small amount from the low point. Or run the fuel line through a water separator, possibly more trouble than its worth in this case. .
Doc,
Water Indicating Paste is used by aircraft pilots. There are two versions, JETA1 for use with Aviation Turbine Fuel, or AVGAS for use with gasoline.
You can buy this at most pilot supply outlets.
Only problem might be that with aircraft, there is a fuel drain at each lowest point in the fuel systems, and the sample to be checked is taken from these, with the paste added to a sample tube. You may have to make some kind of a pipette to extract a sample of fuel from the bottom of the tank.
There are some products that have a consistancy of toothpaste and allow you to put the product on a dowel then dip it in the tank, but personally I'd be worried about some of the paste coming off in the tank.
Wayne
Larson 310 Cabrio
Originally posted by Robyns Nest
Yes,
When I was in high school, I pumped gas as a job....
DAMN, you gotta be 100 years old.
