Water tnk sensor
cmariner32
My 89 Carver Santego has a VDO water tank guage that won't read past 1/4 full. I pulled the tank sensor-is a float with a resistor type head. It will read 5 ohms to about 80 ohms going thru the full range on the float. VDO apparently no longer supports this system. Will a fuel tank sensor work-is the resistance the same? It has the standard 5 bolt tank sensor mounting. I tried to pull the top off the rheostat sensor to check and clean the rheostat but it seems permanantly mounted. Any advice appreciated.
It should not be permanently mounted it might be tough to break loose but you should be able to remove it by turning it counter clockwise. Try tapping on it with a screwdriver and a rubber mallet. The gasket might be hard or have calcium buildup on it. On another point try filling the tank and adding a few gallons of Vinager this should disolve the Calcium and might unstick the rods on the sensor.
Did it work properly at some point in your use? Just asking to see if the sender and gauge are ohms-range matched. VDO range is 10 ohms empty to 180 ohms full for single-station (1 std VDO gauge ) and 0-90 ohms for 1 dual-station sender to 2 std VDO gauges , though they also had US standard gauges and senders for at least single-station at 240 ohm empty to 33 ohms full.
If you have 2 std VDO gauges it sounds like the sender may be OK. Make sure power + and - ground are good. Maybe try good jumpers from gauge to sender and from sender neg to battery ground for a reality check. . Even though the gauge is VDO you might try giving it the "Faria rap."
http://www.autoelectricservice.net/images/VDO_Marine_Catalog.pdf
Their newer water senders are the no-moving-part -type.
http://marine.vdo-gauges.com/fluid-level-senders-accessories/freshwater-level-sender/freshwater.html
Sandy...thanks for the info. It has never worked properly since I purchased the boat. It is a one-station guage. The max it will show is 1/4 full even when tanks are topped off. If I disconnect the wire, the guage will shoot to full. I'm guessing the low ohm reading I get correlates to the low reading I get on the guage when the sendor goes thru full range motion. I tried cleaning the wire contacts but no help. I also tried the "Faria rap" (my version is called Sumbich POS)to no avail. Your link provided some very good info. There is one water sender unit that may work. I will call VDO to see if technical support can help me. Saber....thanks for that info, fuel sender apparently not an option.
Oasis.....I came to that decision after finally getting the cap off the rheostat housing and looking at what I have. After shaking my head, I plan on ordering a Snake River AKA Tankedge unit for $160 unless someone on here can convince me otherwise. I have a holding tank that I would like to add to my tank monitor as well as the fresh water tank. From past threads, Snake River seems to be a very reliable and cost effective monitor.
