Weights and Balances
gcolton
Well-known member
Where can I find data on the balance points on boats?
Would like this data to determine the capability of a 20,000 pound lift forklift to pick up a boat. The operators tell me that they can do a 29 to 32 foot pickup depending upon the balance point.
G
Hmmmm! They pick up my 2855 I/O with a 20K FL everytime I go out /come back. They also do the same with a couple of go-fasts that are at least 36+; one a triple OB, the other a twin big block I/O.
So I guess it depends on your engine/drive configuration for the trim point.
BTW when they P/U those go-fasts there is an awful lot of boat sticking out beyond the fork tines; I think the tines are about 12 to 15 ft long. It occured to me that weight & balance is an aircraft term and trim & stability is the nautical term; but is the case of a boat 10 or 12 ft in the air on a FL that weight & balance is the more correct term. 8-)
I'd use the term, "Center of Gravity" or "Center of Mass". Used by designers in conjunction with Center of Buoyancy to determine stability... ( I thunk. )
I guess that us retired Air Force people talking to forklift operators at an Air Force marina tend to think is air related terms.
G
According to the boatel manager at my marina, their forklifts (Marina Bulls is the model name on the side) use a computer system that won't allow the operator to lift a boat out of the water that is not "balanced" or exceeds the capacity of the equipment. I've seen them lift larger, heavy cruisers up to 35' with no problem.
Have some friends walk slowly from bow towards stern while you watch the water line, the point at which the boat is neither bow down nor bow up from its normal resting level is the longitudinal center of buoyancy IIRC.
It's likely mid point between the "sling here" points. That's what the guy who drives the lift here told me.
