Wellcraft Listing
wizard
A friend has an '87 25' Wellcraft Coastal which lists 2" to port when sitting at the dock.There's nothing obviously causing this (weight imbalance by batteries, storage, etc.). Any ideas?
Thanks, Bill
Has it always been this way or is this a fairly new occurance?
How are the gas tanks/water tank layed out?
I had an '87 Coastal. It did not have a cored hull so water intrusion
is not likely a factor. There is a single gas tank mounted on the centerline.
The boat did have soem limited access issues so water could be getting trapped
in sections of the bilge that are not fully draining.
The oil resevoir (outboard model) is located offcenter, but this is countered by
the battery located on the otherside. If someone moved either so that they are on
the same side that could cause the list.
Capt Tom
Have you tried to drink more beer from the cooler on that side.
2" isn't a lot on a small boat. it could be water trapped by a clogged limber hole. start there.
That Wellcraft model should have a fresh water tank on one side and a waste tank on the other. It will list one way oer the other based on the level of the tanks. Water is about 8 lbs per gallon and the waste tank should be even heavier per gallon.
