Wet Deck Issue
Buckhuntr1
I have some wet coring around my windless. Once I remove the windlass, I only have a 3" hole to work with and I have to get about 12 inches back to remove the rotted coring. I really don't want to open the whole any larger. That's a last resort.
I've been looking into the filler called Sea-Cast. Once it hardens it's 4 times stronger than wood. The only issue is that you can't use anything with it that has an epoxy like Get Rot. So it's imperative that you get all the wet wood out or the issue will continue.
Does anyone have other suggestions or do you know of different filler products that will be strong enough to support the windlass, stop the rot that I may not get to etc?
Thank you in advance for your suggestions.
Chris
“Time Well Wasted"
as you should have access to the anchor locker, you may have yo cut the under side and remove the rotted wood that way. then you can be sure to get to good wood. then you can patch in a new piece and refinish from the inside where no one will see the patch.
Seacast is a bandaid repair. Your first and bigger concern is how water is getting to the core.
Second - how do you know you have 12 inches of coring that needs repair? Have you drilled probing holes? You may have a lot less, or a lot more to deal with.
The problem with Seacast is that you can never be 100 percent sure you got all the rot out.
As Don suggested, if you can get at from underneath, cut the glass from the bottom (leaving the top deck intact), scrape the rotten wood out, resin in new wood (you can use pieces of marine plywood,doesn't have to be pretty), then resin the fiberglass you cut back over the wood, maybe a little fiberglass tape or cloth over the seam and you're done. Make the area around the hole for the windlass and where any of the bolts go though solid glass/resin and you won't have the issue re-occur.
