Originally posted by Thudpucker
Back then, in the Dark I had a pretty bright White 360 light on a mast over my helm.
I'd put a Tin Pie plate under it to keep that bright light out of my eyes.
Thud, now that is a great idea/solution. That will work great on my Supra.
The light config on is different than most skiboats/runabouts. It has the std nav light up front and a white stern light as well. The removable mast light mounts on the deck right below the base of the windshield next to the walkthrough. It runs up at an angle parallel to the windshield to the top and then bends to go straight up another 10 inches or so. This puts the light about 3 feet above and to the left of the helm. The mast light has separate lights for fore and aft.
Running lights gives the nav light,the FRONT of the mast light, and the stern light. Anchor lights give just the front and back lights on the mast.
The problem when running, even with only the front light on the mast lit, its enough light to completely trash my night vision. Kinda dangerous actually. That could explain why i never go above idle at night.
At anchor, both lights on the mast are on. This really bathes the interior of the boat with light; not something you always want. Not to mention it does a great job attracting a unique insect from north alabama. I call it the browns ferry mutant skeeter.
I think your pie plate idea could work very well on Mariah.
OK, sorry for the thread hijack, just wanted to thank Thud for sharing that idea.
