When to paint my bottom...
HarlenW
My boat is currently hauled out for some work and the yard asked me if I want to have the bottom painted. The boat is two years old with its original bottom paint. We power washed the hull and the paint seems intact and functioning well. The boat is in salt water and we cruise at 9 to 12 knots, if that makes a difference. We put about 150 hours or more on per year.
My questions are:
How long does bottom paint usually last?
How do you know when it needs doing?
I guess if it will likely need it within a year, it would make sense to have it done now since it is already hauled out. But, if it would last another two years, it seems to me it would be smart to wait.
Thanks!
I've seen bottoms painted in Key West. Tops too. It will last until you take a shower.
Not to disagree with rburke ;), but an ablative paint should last all season, maybe 2 with a touch up before the springtime launch. As with anything, your actual mileage may vary, but this is what I got when using Micron CSC.
While painting your bottom isn't really recommended, bottom painting your boat's bottom is an entirely different endeavor.
I believe Bruce to be right on track with his advise for boat bottom painting.
My diver tells me that due to the water being warmer in the winter he is experiencing a shorter duration between required periods of painting. I used to get 26-30 months on a bottom job, now about 22 months. This is in Florida on the west coast. Boat usage has not been as active since I started me last business.
Good Luck,
El Sea
1976 Thompson 44'
Suite 44
Depends on what kind of paint you have. If you have multi-season ablative paint and no bare spots, you still have anti-fouling properties. If you have hard epoxy paint, you only get about one season of anti-fouling action despite still haveing good paint coverage.
You can get more than one season out of hard epoxy if you leave boat in water over winter season. Extended haul out causes copper to oxidize when exposed to air. One friend is on his fourth year and another on his third here in NJ. A two day haul out won't hurt to wax & then launch.
Ha ha ha He beat me too it... That was what I was thinking when I read the post. I am not in salt thus I cant give you a good recommendation but showers are always good everyday
Greg & Bob nailed it (although rburke makes a good point as well :)).
A lot depends on the area in which you boat. What is typical in Florida will not be typical in Washington IMHO. Talk to folks with the same type of bottom paint in your area to see what is typical. Of course, the guy wanting to do the work will tell you it needs it. That may or may not be the case.
If will need it redone within two years, you might as well get it done now......
I would be more worried about developing a rash, than incurring build-up. Oh, you mean the boat...
