Where's your number
Riverbed
For documented vessels, "the official number shown on the COD, preceded by the abbreviation, 'NO," must be marked in block-type Arabic numerals at least 3" high on some clearly visible structural part of the hull." Where's everyone got theirs? I'd like to find a "tasteful" place that fills the requirement but doesn't look "cruddy."
I have used vinly letters, covered with a thin layer (3/4 oz) fiberglass cloth in epoxy. In most boats in the engine room in a structural bulkhead. In outboard boats--under the dinette table. These numbers do not have to be visiable from the outside--just in a place where they cannot be removed and typically were "engraved on the main beam".
Ours was inside the ER, on the transom applied as Bob described above.
on my boat, i have a plate of aluminum that has an 8 to 10 digit number "hole punched" into it....if i remember right, its a series of numbers and maybe a letter or two.....is this a documentation number ?........my boat is a '64 model so there is no hull number anywhere.......
now that i think about it, it does start with the letters NO..........i thought that was an abbreviation for "number"
so is it safe to assume its a coast guard documentation number ? if so, how do i go about tracing it back and finding history on the boat ?
will i still need to display a state registration number ? and if so, can it be displayed like a little sign hanging from the front rail ? im in north carolina
In the bilge as above, hidden from plain view. I doubt that hanging the numbers off the rail "like a little sign" is legal in any state. As to the need to display state registration numbers, not legal to do so in any state on a documented vessel. It sound as if the documentation of your vessel has long since expired.. They need to be renewed every year or the vessel is dropped from the documentation rolls.
I milled the documentation number into a piece of 3/8 aluminum plate and mounted it per coastguard instructions the engine room wall.
Thanks for the input, all! The boat's new to us as of the end of last year and although the previous owner had it documented, he had no number displayed and since we boat in an area with a lot of Coast Guard, Secret Service (Bush Kennebunk compound) and general high enforcement activity, I wanted to keep it legal. The "NO" does have to precede your doc number and no, the hanging sign off the rail doesn't work. Engine Room under fibreglass is the winner - thanks for the idea!
Cheers-
I'm not sure where it is, but several women say they have it!
ok....so ive figured out that i wont need to show state numbers if i document....
and if i do register with the state that the "little sign" from the rail is a no no...though i have seen more then one boat display them that way, thats why i was asking, thought maybe it was a state by state thing.....
the numbers on my boat are as follows........ NO 541309 NET 8......i dint find anything on the CG site, is there an archive i can go to in order to research it ?......what does the NET 8 stand for ? 8 tons ?....its only a 10,500lb boat
if i decide to document, what are the advantages of doing so ?...disadvantages ?......would the number remain the same ? or would i recieve a new one ?
thanks for the help and advice
Stands for 8 net tons. Measurement tonnage has ABSOLUTELY NOTHING to do with the weight of the boat. It's a measure of VOLUME. If my memory serves me correctly 1 measurement ton is 100 cu ft. NET tons takes into account deductions for the engine room, crew spaces, etc.
Your boat was documented, but now dropped from the roles. You will have to provide clear title to re-document--and you will use the same number--this is assigned permently to the boat. A document must be renewed (free) each year. If not the vessel is dropped. Do you have clear title? You also have to have an official bill of sale-all of the information is at: http://www.uscg.mil/hq/g-m/vdoc/nvdc.htm
If you don't have a clear title you will have to provide it--and this may take some detective work. There are few advantages to documentation--slightly easier clearing in and out of foreign ports, some lenders require it, because it gives a good trail of liens. You can obtain an abstract of title from the CG--and it will tell about it's history. I suspect you will have to call, since the vessel has been droped.
As for the plaques tied to bow rails--most states reqire state numbers to be attatched to the hull. Some inflatables, and dealer's boats will have the numbers on plaques.
