Which Depth Finder/GPS
bobn
I need some advice as to which depth finder/GPS combo to replace an old Hummingbird. This will be installed on a 37 Chris Craft, used on the Tennessee River, no offshore or coastal use. I'm leaning toward Lowrance. I want one I can use to hook up other electronics later, flow meter, etc. And this brings up another question if I use it for a flow meter also. Is there an advantage to having the flow meter with the combo unit or would I be better off with a seperate flow meter. In looking over all the different models it's getting harder to decide which would be best for my use considering I'm not sure what I should be looking for specifically. It will be used primarily for the depth chart, but will be used sometimes to mark certain spots.
Thanks for any advice.
Bob,
I have a Garmin 178 (don’t know if they make this model anymore) with a shoot thru hull ducer. Overall, a good GPS unit. It has an output wire that connectscommunicates speed to my LOWRANCE LMF-200 on a NMEA system for real time mpg. I like the NMEA system and want to add other components. I did not spend a lot of money for this set up (always a relative thing in boating); don’t know what your budget is. My previous GPS was a Lowrance…and in some ways I liked it better than the Garmin. (Screen size, ease of use)
As we spend a lot of time on the lake far from any marinas in rather remote areas, sometimes with no cell phone coverage, having a firm handle on the fuel is important. Also, we don’t carry around more fuel than needed.
Appreciate having you on the board and good luck in your hunt. Don’t hesitate to e-mailPM with any questions, I’m always around.
There are many on the board with more experience regarding NMEA andor other systems than me. My impression has been a general thumbs up on NMEA. Looks like your question fell through the cracks.
Boatfix has prices good as anywhere, if not better. You can always calle-mail Mike for suggestions.
It's nice to purchase from a place that you can call someone for real help. He has never failed to call me back when needed.
Have you looked in the online catalog?
Would love to visit the Tennessee River one of these days.
Stan
Today is the last day to order any of the specials running at Boatfix........
You will get a lot of different opinions, and you should look at the units somewhere and see which seems to fit you. I choose a Lowrance 339cDF-iGPS because I liked both the controls and the split screen orientation (up and down giving a side by side screen view)
This is a color chartplotter/GPS unit with internal GPS antenna and a dual frequency depth sounder I wanted that for deep salt water use.
I also now have a NMEA 2000 network and fuel sending unit on my Volvo 5.7Gi (EFI engine) -- everything works great and I have it set up to give me the a GPH and MPG readout on my screen. I have had ZERO problems with my unit. I ordered an extra map chip when I purchased it. After looking at the base map in the unit I knew it was not good enough and so I was able to factor that cost into the buying decision.
If you have a larger boat -- and/or a larger budget, then a larger screen is always a positive.
I have about $900 in my complete system -- that is the unit, and network backbone, and fuel sender, and extra chip. We have had our system now for a little over a year.
Garmin 520, 530, or 540 series. Make sure it has the "s" after the model # designating that it does indeed have the sounder option.
I had a Lowrance combo unit on my fishing boat and I was very happy with it. It was still working faultlessly when I sold the boat 8 years later.
Lowrance (and others) make units with INTERNAL antennas and units with EXTERNAL antennas. The internal antenna units work great on fishing boats and the fly bridge and are easier to install. If you're installing in a wheelhouse though you may need a model with the external antenna, which you can mount on the roof where it'll get a better signal.
