Ok guys and gals here is my problem for you to ponder or better yet answer. I have a sea water pumo on my a/c unit that is not pumping so I took it off the c/c and here is the info on it , its a cruisare model no.PM250 , 115 volts and it has a white wire, a black wire and a green wire with a yellow stripe on it. I want to bench test it to see if I can find the problem and I need to know which is the hot wire and which is the ground wire? The c/c is a 1986 but from the looks of the cooling unit is is not that old. It cools great as long as I supply cooling water from an attached hose fron the house. I would appreciate any info you can give me and wld love to find a schematic on this unit. If I knew where to find the serial number and modle number on the cooling unit I would supply it . But as fellow boaters owners you know there is not enough room to manuver around the unit to find it . Pls help me out here cus its still hot in sunny fla and I need my a/c tks Terry-------------------------tboss
