White Steam
Edgar
A friend of mine has both '97 454 Crusader TPI Full injection engines white steaming... We already check for coolant loss and pressure tested and there is no water loss. Compression check, spark plugs clean and without water. Leak down test. Manifolds and risers looks good. Valves check. Fuel tank free of water. What are we missing?? What else we can do??
My '94 carbed, 454 Crusaders produce like amts of steam always. Some days, with cold water or air, they produce more, but always about equal to each other. I frequently check temps of both engines with a temp gun, have no overheating issues or hot spots.
Mine (454)is a 99', carbed and it has always let out some white steam, more when the water is colder.
Same here, 350/270 crusaders. On a very humid day I could pass for an old locomotive. Great engines though.
I like it, looks cool. James-bondish ;)
I produce a lot of steam in coller water. If it's excessive, I check the strainers (should be reqularly done anyhow) and impellers first, since this is easiest and has been the culprit most times.
I posted about my 2001 Crusaders 5.7L engines steaming also. In my case, I haven't checked the impellors but will replace them soon. Similar to everyone here, there is no over heating and both engines match. Could this simply be normal crusader behavior?
My fresh water cooled 454 Crusaders have steamed since I owned my boat. Not an issue.
