Why have bottom paint?
dsmboosted
I am new to boating (as you will see with this question) and I am wondering...
Why does a boat need bottom paint? I have a 1986 Sea ray 300 weekender (about to purchase actually) and we have to redo the bottom panit. The boat will be docked in a slip all summer. What is the main benefit of bottom paint and why do boats need it?
In fresh water? You may not need bottom (antifouling) paint. I have a small boat that spends every summer in a fresh water lake in NY and has never been bottom painted.
Oh. So the paint has some sort of growth inhibitor in it or something?
Also, Does th epaint affect the fuel efficiency of the boat at all, i.e. better efficiency because of a smoother surface?
This is a freshwater boat.
he boat I am buying currently has bottom paint, but it looks like its about 500 years old, peeling and missing paint etc.
dsmboosted,
Congrats on your upcoming purchase. We keep our boat in a slip in Sturgeon Bay from late May to the end of September. Our boats have always been bottom painted, but those boats that park in their slips and are used mostly for a cocktail barge with an occasional trip to the beach thrown in look like a salad has grown on their bottoms by the beginning of August.
Bottom paint is designed to scale off over time and take the growth with it. Bottom painting is one of a boater's least favorite jobs, but I wouldn't keep my boat in our freshwater slip without it.
Thanks Len.
I have been reading some of the forums on bottom painting and how to remove. We have a 30 footer and are NOT looking forward to removing the paint. We are doing it ourselves. Do you use chemicals to remove the old paint or do you scrape?
First, welcome to boating and BoaterEd.
Now, to your question. Len stated it pretty clearly but I'd like to expand just a bit.
First, there are 2 main types of bottom paints. One is an ablative which, as Len described, has some marine life inhibitors in it but it is also designed to sloth off as the boat moves through the water. This action helps to keep the growth slothing off with it and it exposes fresh inhibitors. Ablatives need to be repainted every 1-3 years depending on which quality paint you use and the number of coats you apply. Its a pretty common practice to lay on a base coat of one color like a red and follow that with 2 coats of another color, say black. When you see red showing through the black you know its time to repaint. The main advantage to an ablative is that its a multi-season paint (meaning it does not lose its effectiveness if the boat is out of the water for any length of time) and when properly applied there is no buildup of coats that will eventually need to be scraped off; it wears off.
The second is a hard paint. These paints do not wear off and the do lose their effectiveness if the boat is out of the water for more than a few weeks or so. Since the coats do not wear off eventually the bottom will need to be scraped or blasted to get that build-up off. Hard paints are favored by those boaters in the warmer areas where the boats stay in the water year round. The advantage of a hard paint is that it has less impact on boat performance than an ablative, although I'm not sure how much of a difference it makes to the normal family cruiser.
So, how do you tell which paint is on your new boat? Take a rag and rub it on the bottam paint. If you get chaulk like paint rubbing off onto the rag then you have an ablative. If it comes off in chunks, flakes or not at all then its likely a hard paint.
Lastly, keep in mind that you can paint an ablative over a hard paint that is in good shape but you cannot paint a hard paint over an ablative... it just won't hold.
Hope this helps!
Some hard paints can be burnished to a smooth finish. The boat will go faster - racing sailboats will do this. I would also ask the seller exactly what paint he used.
Ther is a third type of bottom paint--actually the one which is probably most useful in fresh water. THe thin film vinyl paints have a growth inhibitor of copper patricles. the paint is a very thin film which has modest inhibition properties and does not build up. Typically these paints are modified using teflon which acts to decrease there friction in the water. I used the paint on my vessel in Lake Erie and have had very good luck with it. You must first remove the existing paint--I used a non-solvent stripper made by Dumont--it is basically a sodium hydroxide material (lye) in a thick base.
I slip on Lake Michigan and probably have similar water conditions to your location. I stripped my first boat and slipped it unpainted for a few years. I use the boat weekly so the growth didn't accumulate to an extreme amount. There was an algae slim all over the hull when it came out in the fall. That stuff when dry became nearly impossible to get off. An acid wash was required to make it happen. After a couple years of doing it myself and taking acid baths, I had it done by the marine service that I used. The cost of that process more than eclipsed the cost of bottom paint given a normal life of about 5 years for the paint. With paint, a quick power wash at haul out and you're done. That's included with my haul out. If you strip your hull, you're likely to find a gel coat surface that has been scuffed with 80 grit sandpaper and will require wet sanding to get the finish back if that is even possible without going through the gel coat. My recommendation would be to either strip or sand the paint that's there and reapply paint using the proper processes. My experience was that it ultimately is the most cost effective and least maintenance of the options available.
dsm - if you're prepping the hull for new bottom paing by sanding, be aware the paint dust is I think quite toxic, and the little paper masks just aren't good enough, you need a proper mask for this job.
Good luck
Orcbait
Still on topic, but as a bit of a sidebar:
MikeeH said: "Hard paints are favored by those boaters in the warmer areas where the boats stay in the water year round."
I disagree. I would not use anything but an ablative ( in my case, warm, salt water ). It is the only thing that actually provides some "protection". The hard paints ( an epoxy base with biocides ) will work for awhile ( about6 mo ) them you need to refresh. After several cycles of this mess, you need to remove the "dead" epoxy paint. The hard paints -do- create less drag ( from the paint ). If you race your sailboat, use a hard, smooth anti-fouling paint. But in this case the performance benefit is worth it. Ablatives ( as in "self-removing"!!! ) work well against the fast growing aggressive barnacles and green goo. And though there is a slight increase in drag vs an unpainted bottom, a few weeks in the slip and you will have a bottom that resembles the moon, and mine will still look yucky red and work as well as the day the test started.
Many of the hard biocides were developed with the less demanding environment of a fresh water, cool season in mind. ( Partly because the early biocide types were not terribly aggressive. )
Note that in these days of ecological concern, the laws relating to bottom paints have been evolving rapidly. The old ablatives ( I forgot if it was lead or copper. Lead, I think. ) were taken off the market as a marine contaminant. I suspect that the biocide types will be included in the ever increasing scrutiny as well.
For cool area, freshwater boats that do NOT sit in the slip more than a week or two, you likely can avoid the entire issue, and "wear a bare bottom".
For cool area, freshwater boats that DO sit in the slip more than a week or two, youshould seriously consider bottom paint. Visit the individual manufacturers websites to wee what they offer that is designed for your conditions. ( Or call them. They LOVE to sell this stuff. ) You should also ask around several ( many ) boaters who boat the same way as you do, in the same area and get their comments. Sometimes, local wisdom reigns king.
For salt water use other than trailer boats, I would strongly advise using bottom paint appropriate for the boat type and usage. In most cases, this would be an ablative, but, again, contact other locals, in your area, as well as the manufacturer of the proposed paint.
Asto color:
MikeeH got it right: use one color for the first coat, then a different color on top. As far a "looking good", well, all things are relative. some of the hard paints do actually look good. IMHO, none of the ablatives look very attractive, though some are a bit better than others ( mostly due to the fact that they are "built to fall apart". By design they look like a three-day-old sunburn... )
Addendum: As other posts have indicated, this is a fast changing product. None of the bottom finishes are pleasant to use and none are perfect. Add in federal regulations, and things start to change rapidly. So don't forget to -call the paint manufacturer- ( not the paint retailer! ). Apply their product as they describe.
To pollute the canals, increase drag and yield heavy metal poisoning too! And what everyone else said also...
Trailer it or dry store it if possible.
Dsm, I am just a few clicks south of you in Winthrop Harbor. In our conditions you'll get a nice slime buildup on your bottom. On non painted boats it will leave a mark. Thus, I would continue to bottom paint the boat. I would stick with ablative because you will be out of the water at least 5-6 months per year. At haul out, you'll have a 10 min. pressure wash and she'll be like new. You'll probably get at least 3 years out of a two coat job. Figure out if you have ablative now -- it will rub off on your hand or a rag. If so, you'll have an eaiser time preping the bottom. Prep it as good as you can. Beware of sticker shock when you price out the paint -- its generally around $100 per gallon last time I did it. Good luck and hope you enjoy the boat.
