WiFi Help...
http://www.cradlepoint.com/products/phs300-personal-wifi-hotspot Yep I think Cradlepoint is what you need.
Mark what USB Verizon card do you have so I can find you the external antenna interface cable (really important).
For those with Windows Mobile PDA's, I'm typing this as the Admiral is surfing the web on her iPod via wmwifirouter.com on my Verizon PDA. I do the same thing at our ski place out in the middle of western PA with 4 of us online at a time via my PDA. The PDA becomes the WiFi hotspot redirecting the CDMA signal from Verizon to WiFi for users to connect to. Heck, I've even done this in the Bahamas off BaTelCo towers! Right now I'm getting these speed results in downtown B'more (and I'm waiting for a replacement PDA as this one is on it's last leg):
http://www.speedtest.net/result/607789238.png Here is the Ericsson W35 on AT&T with 2 of us on the WiFi re-broadcast.
It is a Pantech UM175. It does have a very small port for an external antenna.
I will go check to see if there is an adapter to hook up and external cellular antenna.
http://blog.wpsantennas.com/2008/08/verizon-wireless-um175-usb-modem.html Here you go now combine this adapter with a Digital antenna 563C and this will also help.
So, once you have your card connected to the router, do you launch the verizon software (VZ Access Manager) from both computers? Or can everyone use the access once the one computer has made the connection?
I get pretty good reception up to a few miles off shore, sometimes much farther. Does the external antenna make a big difference? I suspect it does based on your enthusiasm... :-)
If you are going to do any traveling it helps. The better the CINR or signal to noise ratio the higher your speeds will be. However do not purchase an amplifier even the direct connect amplifiers seem to slow the data rates down because they lack filtering and can go no linear causing poor speeds. Remember now that you will be plugging the USB modem into a router and access point that will be located in the boat. You may or may not need to use the connection manager, I know I don't have to use the connection manager with my KR-1 and Novatel 620 modem.
I have not tried the KR-2 I am sure it is a quality device.
Here is my Sprint connection speed through the Shakespeare CN1100 modem the signal is EVDO.
report refers to a connection test carried out by IP address 173.124.169.252 on 31 Oct 2009 14:57:29 GMT-05:00.
Download speed 737 Kbps
Upload speed 595 Kbps
D/load QOS 81 %
U/load QOS 78 %
RTT 116 ms
Max Delay 168 ms
Avg Delay 15 ms
Max Bandwidth 880 Kbps
Route Speed 4519 Kbps
Originally posted by Starry Night
I use a Cradlepoint MBR-1000 air card router for my VZW usb air card on the boat. I have had 4 laptops running and not an issue. I also used it on vacation while cruising and no crying from my kids. They also have a new GigaBit N router, the MBR-1200.
http://www.cradlepoint.com/products/mbr1000-mobile-broadband-039n039-router
http://www.cradlepoint.com/products/mbr1200-failsafe-gigabit-n-router-mobile-broadband
When using my my pc's I do not have to open my communications manager from Verizon while it is in place in the router. After first installing and setting up the router I only need to add my passwords on the secure network page.
Bill thanks for the antenna suggestion and adapter for the VZ usb card. I may install this on the boat before spring.
Thanks again for all of your collective help. I have one last question. In addition to generating a wireless hot-spot with my verizon card, will these units also pick up other local wireless networks? For example, if the marina has a wireless network service, can these routers pick up that network and use that instead of my verizon card? It would be nice to be able to switch back and forth easily. I'm a little worried about exceeding my 5 gig download limit. We use the computers a lot.
No you need a sperate WiFi only router. I highly recommend you look at GeoSatSolutions.com they used to be called Syrens. I use the 1 watt unit with a 10db omni on the hardtop it has its own rebroadcast you'll need to set both the Verizon router to say channel 1 and the Syrens output to channel 11 or better yet both in automatic. Also keep both power levels as low as they will go so you don't interfere with your Syrens high power WiFi picking up distant stations. I am able to routinely log into my marinas Access Point (also a high power Syrens Access Point unit) with a directional panel 7 to 8 miles away with decent throughput speeds. So again in closing you want the Verizon card with an external Cellular antenna into which ever router/access point you choose and the stand alone WiFi system to have its own WiFi omni antenna and mount the WiFi box as close to the antenna as possible. Right now my wife is on our Syrens unit's ap receiving the marinas WiFi and I am on the KR-1 with my Verizon 620 air card on an external cellular antenna using a jumper from Wilson electronics. I decided to play with my Verizon KR1 this weekend because where I am relocating in a year or so Verizon is the best carrier and I think the only 3G carrier. But I will see because I can go over to the Ericsson W35 on AT&T's 3.5G network (which is also my boats primary phone line) or Sprint and in worst case my VSAT Skipper 150 if I want to pay almost $11.00 per 1mb! As a pho0ne it is fairly cheap .99 cents a minute and .55 for text messaging that I can also send my GPS position with. I am pretty sure my Nextel (IDEN) (boats 3rd phone line other than Skype) will not work where I am going but we will see.
I can answer 1 earlier question with the KR1 you do not need the Verizon Access Manager.
It automatically goes to the highest grade of service in the area either 1-RTT rural/ EVDO or EVDO.rev.A. You actually open the KR1 connection with your computer's connection wizzard or utility.
