Ok I'm working on windlass now... It's a Simpson Lawrence on a 95 model Silverton. First, previous owner owner said it quit working years ago and never worried with fixing it. I found wire from dash swith unpluged. Started working but only for 20 secs or less then tripped breaker in ER. After using over and over same thing. Starts out running for 20-30 seconds then trips the more I try the faster it trips. (hot)? It will let chain/rope out but will not bring back In. Sitting in slip I can drop it to bottom (18 foot) and it will not finish picking it up.
I removed it and have it in my garage. I pulled it apart in two. The top where the rope/chain wrap around turns freely. Any ideas? Could the motor be bad? Any way to test?
