I have a 97 Carver 355ACMY with a Maxwell 800 freedom windlass. I posted a question back in 2012 regarding pressure arms. Everything went well after the help I got. I recently noticed that the pressure arm pivot hole in the deckplate is corroded to such an extent the pressure arm clip won't stay in. I also noticed that the windlass shaft wobbles as it rotates. I know the deckplate is approximately $500.00 and who knows why the shaft is wobbling. Do you think it is worth removing and shipping it off for repair or should I consider purchasing a new windlass because of it age? If the latter, what is the best windlass out there? Thanks for the help.
