Winshield Shade Cover
Crossroads
Anyone know what the material is called that those windshield shade screens are made from. The screens that allow a person to see out but block most of the sun. I thought I might consider sewing one myself but I'm at a loss as to what the material is and whether there's an online place to buy it.
I'm not familiar with the Textilene but Phifertex is another alternative. It's like a screen that has been dipped in vinyl. you can get 70-95% sun blockage with their different products and it holds up very well to the elements.
We used white stamoid, but Sunbrella makes the material that can be seen through. I like the white stamoid because it keeps all of the heat out. We install them on our windshield, side windows and the two sun roofs. Even when we are docked, we put the sides on to keep the guys next to us from seeing in.
I used black Phifertex 90%. Can see out during the day (barely at night) and can't see in at all at night, even with the lights on.
Can't imagine why someone could not see in at night when looking thru perforated windshield cover when it's lighter on inside than on outside. Just law of physics.
If you are standing on the finger dock and put your face right against the window you can see in. If you're more than a couple of feet away, all you see is shadows. If you're farther away than that, you can tell a light is on in there but can see nothing distriguishable.
I'm sure that physics are indeed involved here and they wouldn't sell much of these products if they didn't work as I have described.
phifertex and textilene are pretty much the same thing, just different brand names. I made screens from the regular phifertex and it wouldn't give much privacy so go for the phifertex 90% which is a much tighter weaave. The Sunbrella sunshade material may be better as its specifically designed for this application. Try and get some samples before you make a choice. It all depends on how much privacy and sun shade you want. If you don't care about seeing out, go with regular Sunbrella or Stamoid. You can sew this yourself if you have a decent sewing machine. Older all metal machines are best..nothing newer than the late 1960's vintage. Pattern the window with a 6mil plastic sheet, transfer it to the material and then bind the material with acrylic (sunbrella) binding. Use UV resistant polyester thread such as Dabond size number v69 or 92. You will then have to add snaps or common sense fasteners to hold it in place. You can find a lot of info on Sailrite's web site.
Skeetobite, maybe the ones I've seen have 1/4" perforations. I could easily be 20' away and as long as it was night time (dark) & interior of boat was lighted; I could see in quite easily. Go figure ! I have heard of some boaters buying this type cover & were not aware of this phenomenon until installed. Then it was too late.
You say sell as much as they do....In over 30 years of boating; I could count on the fingers of one hand the number that I've seen. Maybe, like you say, they are so good I didn't realize I was lookin at one ! Then again I don't go sneeking around the marina at night looking into boats.
Bob, I'll have to put up some pics. we're going down to the boat this weekend and I'll get some pics together. the 90% has a very tight weave and from very short distances it looks like the windows are "limo tinted" instead of covered.
The vast majority of boats (of reasonable size) down here in Florida have at least some type of widow covering to keep the sun out. So I see this stuff all the time here.
The material that allows some visibity is called "scrim" and is available from many sources. It is used a lot in theater for special effects.
One aspect to which one must pay attention is the fact that the transparency value, such as 40% transmittance, is when looking straight on, not at an angle. A windshield is usually at an angle and if the angle is radical enough, you won't get the visibility you want.
the fact that you can see through the material from the outside when it is dark outside and light inside is one of the keys to the special effects that can be achieved with scrim. You should not rely on it for privacy.
Another issue I have found is when the shades get wet from a wet and windy ride, they are very difficult to see through during the day or night. I normally remove the windshield shade, but leave the side window screens up while cruising. I have had to stop enroute and remove the wet shades to allow me to see through the side windows.
