Winter blocking
hounddog
I called the marina 3 weeks ago to fix the rear keel block on my boat. It was not doing anything, it is a 34' and they had three total under it. Well I went to work on it and they re-blocked it without lifting it. they took a larger piece of wood and a larg hammer and drove it in, well they also ripped out the drain plug bolt. I have to call them tomorrow and see if they will make good on it. I do not know if I want them to touch it if that is the type of workers they have. Has anyone delt with this sort of thing before?
No. I'd make sure they repaired any damage they did. Maybe think about storeing someplace else next year.
Never, but that is gross negligence on their part.
Well, I called them today and they said someone will call me back. The boat can not go back in the water till it is fixed. So it maybe sitting on there lot till done. I do not think I want them to fix it. I want them to give me the parts and I will do it. well anyway I will take before and after pics just incase I let them repair.
I will let you know what they say if I get a call.
Was it a srewed in drain plug? If so and ripped it out that was a LOT of force. Take a good look at the fitting and guessing that needs to be repaired/replaced to and the fiberglass surrounding it.
Get them to put in writing they were reponsible for the damage.
