Dritter:
Instead of PVC, I use 3/4 inch EMT. 36-foot aftcabin Uniflite. Ridgepole is supported by four pieces running to deck with rubber feet. Borrowed pipebender to bend ribs running from ridgepole to handrails, about 4 feet apart. I bent the ribs about 4-6 inches above the handrails so that the rail does not form a pocket in the cover for melting snow to gather and freeze. Connect ribs to ridgepole and rails by using KoverKlamps. Had originally used PVC "T"s with hose clamps to keep them from moving, but they kept chipping. The KoverKlamps were probably the most expensive part.
Have used this frame for 10 years now, except for a few pieces that fall in the water each year. Yup, I winter in the water north of Boston. Have used poly tarps previously and shrinkwrap for the last 4 years.
Gene
