Drain hot water heater first, then blow out the hot and cold lines, no need to bypass water heater, leave the compressor on the system with pressure and the ice maker will cycle a few times and blow out all the water that's left. No pink standing in the lines over the winter to avoid that pink taste and smell.
Flush the toilets ie: Vacuflush (if you have fresh water head) and it will blow out air, pour/flush pink down the toilet to winterize downstream, and holding tank.
You just have to go to Lowes or HD and spend 10 minutes getting all the adapters to go from the compressor air hose fitting to garden hose fitting. I put a little brass inline shut off valve right before all of the adapters, makes it easier to work with.
Then go to MarineEast . com and get the "hose to garden hose adapters" and you can use that to blow out most of the other systems like the A/C, salt water washdowns, thru hulls if you stay in for winter.
