Wireless Webcam
n715tm
I currenty keep my boat 4.5 hours away from me. My marina has wireless service that I pay for each month. I have a unique username and password which grants me access to the service (Hargray Internet). Is it possible to purchase a wireless IP camera which would be able to connect to my internet service and allow me to view the boat from my home computer? I prefer a stand alone camera which does not need a PC to operate. If possible specific brands and models would be appreciated.
Tobin
Does your marina have a security camera that they would allow you to "tap" into? Would save big $ and trouble.
Where would you put this camera? In the boat; on the dock; attached to adjacent building? AC or DC? Lots of other particulars that need to be answered.
No the marina does not have a security cam to tap into. I would leave the cam on the boat maybe 2-3 cams if possible. Most cams I have looked at on the market are A/C converted through a wall wart to D/C.
X cam has an ac/ batt operated security cam system. The batt operated only lasts a short time so AC needs to be available. They have a set-up that you can access thru your home(or any computer). I had their 3 cam set-up. for the house. It lasted 10+ years.
Check out Pascal's set-up for his boat. He has some info on his post about his trip to Nantuckett
http://www.stardot-tech.com/ The camera has its own IP address so you do not need a computer, just access to internet.
It's fantastic here, but it looks pretty bad in NYC and Brooklyn!
Doesn't appear to be wireless. I am not running a router to connect the camera to on my boat. The camera needs to be able to be configured to pull an IP address via DHCP from a wireless hotspot.
The reason I ask is that you will need to perform some set-up directly with the router. In my experience (and I am no expert), you need to perform some initial set-up while the camera is is wired directly to the router (even though it's a wireless camera). Also, you must do something called 'port forwarding' - which is pretty straightforward once you figure out how to get to the settings in the router. I have three separate camera's at my lakehouse - I use Panasonic which I find to be high quality and with a good user interface. Also, they include a DDNS forwarded service so you do not need a static IP address. I would recommend this one for outdoor wireless use - pricey but it works really well.
http://www.securityideas.com/panasonic3.html
You can 'test drive' the camera on the link above. BTW - it also has audio so you can hear what's going on and if you connect an external speaker you can 'talk' to whoever is near the camera. Pretty cool!!
Thanks for all the product links. I think I may have to go with an "air card" type solution. The wireless internet at my marina is part of a island wide wireless infrastructure. Hargray who is the provider said it will not work since the connecting device needs to have a web browser capability to login to the service once accepting an IP address. The procedure is similar to a hotel wireless access point where a login sor confirmation screen is splashed for you to provide credentials or confirmation.
I looked at a air card service from Verizon (my current cell provider) and they have a limit "If usage exceeds 5 GB/line/month, we reserve the right to reduce throughput speeds to a maximum of approximately 200 Kbps." Not sure what this equates to, but I would want them to reduce my internet speed.
My last option would be to have DSL service delivered to the boat. Depends on availibility and cost.....
If you think about that, you'll see why that will not work. ;) If the camera is getting a DHCP address, then you never know what address it's at. Also, that connection at the marina is most likely NATed outbound, without translation back inbound from the Internet proper, IE there's no way to reach the internal addresses from the rest of the Internet without it being setup that way.
if you go with an air card and PC service, you need to make sure your system will restart on its own otherwise when the connection, power or computer goes down, it will not restart.
when using Cingular/ATT for instance, their Connection Manager will not restart the connection unless you are there to click connect. But Sierra's 3G watcher which you can DL from Sierra's site will automatically dial on start up and redial when connection goes down.
5GB is plenty. I run my webcam at 640pix size and 5 to 10 seconds refresh, 15 hours a day and don't come close to 5GB a month unless i download a lot of stuff, but i use my computer every day and do a lot of stuff on line including web design.
on the sofware side, you also need to make sure that whatever you use will automatically start/restart. Active Webcam (PY soft) which i use has 2 version. the basic version starts automatically but not until you have logged in. The full version has an option to start as a service so that if you have multiple users and need to login to windows on a restart it will start even if no one is there to login. otherwise, use a PC with no user and no win login.
another alternative would be to use a wireless router in which you put your aircard, with a network webcam. a little more $$$ (those routers cost around $200 i think). I believe (not sure) that the aircard will run in the router even if the PC is off. there are a few of these routers available but you have to get the version for your aircard and provider.
The panasonic camera that I linked to will allow the connecting device to have a web browser capability to login to the service once accepting an IP address. It's the set-up that might be an issue.
