Wolverine pad heaters
David M
The search function is not working tonight...Or I'm not functioning correctly tonight. Take your pick. Two RO's have mentioned wolverine oil pan pad heaters in the recent past.
Can these (either wolverine or a like product) be used on gasoline engines. The manufacturer says yes, but they are in sales. The local distributer says yes, but they are in sales as well. I like the price, but more so I like the lack of yet another thing in the ER and the fact that radiant heat on a timer or t'stat is far more efficient than a boatsafe or extreme air heater.
TIA.
You're in VA, thus you're a little warmer than I am in MD. I've stopped winterizing altogether and switched to Xtreme heaters. If you leave your boat in the water, you'd be fine with engine room heaters. The water below helps keep the engine compartment warm and the heater helps fend off the cold from above. To be honest, I have no clue what the Wolverine heaters are like (although another post...Regal forum?? said they're great for diesels), but I did hear their cords are rather short. Xtreme heaters have very long cords (so the spark factor in the ER is very, VERY low). And there's no need to keep something stuck to your oil pan all year like with Wolverine. Oh, and will the heat from the pan make it up to the risers??? How 'bout the rest of the stuff in your ER?
I ran 2 Xtreme heaters last Winter and only saw about a $15 increase in monthly electric. Thus, I'd say I'll end up breaking even in a few years.
The bilge heaters are great IF you have dependable electric power at the dock. Think about the possibility of ice/snow storms knocking out power. If you live quite distance from the marina it may be a problem .. it is for me.
I find that the advantage of heating the engines as oppose to the engine room air, gives a greater length of time retaining heat after a loss of power – the engines become like 2 big hot rocks – in my case over 5000lbs of hot mass which takes a very long time to cool to freezing temps
I don’t have any experience on this with gas engines, but if the heater manufacturer says it’s ok ask them for a copy of the insurance certificate [:-bigeyes]
Andy,
Did you ever find out what type of block heaters you have?
Jonathan
Originally posted by Robyns Nest
Andy,
Jonathan
[:-banghead]
I will get over to the boat in a day or so and confirm
The Wolverine pad heaters come with a 6 foot cord. I don't know for sure, but I would guess that 6 feet of cord, routed from under you oil pan, will not reach outside the ER. Assuming that the device itself were safe for a gas ER, the next question is one that has been discussed here before.....is an AC outlet "allowed" and/or safe in gas ER?
Mrs. Robinson had a spark proof outlet put in his 330 Dancer last year. The electrician hard wired it to its own breaker. I have seen several gas boats with this arrangement. I am leaning more and more toward the pads because of the way they work and the size. The marina power is very reliable, and if the grid itself goes down, the idea of hot iron taking a couple of days to cool down.
My mechanic was working on my gennie today and told me the condensation in the ER was unbelievable. We have had some 35 degree nights followed by 60 degree days. A couple of thousand pounds of cast iron in that temp swing in an enclosed environment can't be too good for too long.
I have them on my diesels and love them. I would not hesitate to put them on gassers if it was a very well maintained engine room. Some owners have hardwired them as well which may give you and others more piece of mind.
wrkalot....do you still winterize your engines or are the Wolverine Pads enough to get by? Also, what size Pads do you have?
Dominic, I have 250 watt pads for a 13 quart oil pan. Just on the edge but I felt that 1000 watts 2 x 500 was overkill.
Gary:
I also have the 250 Watt pads and I hold 26.5 quarts. I just placed my order last week, so I haven't installed them yet. I called and spoke with the Wolverine tech/owner, and he explained that his "charts" are to get the oil upto 100 deg F....however....that is in a 0 deg F ambient. I told him that I didn't expect to use them as a way to eliminate winterization, just to avoid it as long as I can. I also told him that my ER will never go below 40 deg F. He said that the 250 pads would work just fine in my situation. Also, I figured I could always add a second pad if I did decide I either needed more heat or not to winterize. That way, I would have 500 Watts per engine, but during the warmer months, would be able to shut one down and reduce the energy draw. These pads have no thermostat, they are "on" or "off".
I have the 250's as well and do not winterize the engines. I live aboard 7/24/365 on the Chesapeake. I would winterize if I lived a good distance from the boat though. I want to get one for me genset but I'm not sure where to put it... yet.
I also leave them on all of the time (except when the engines are running). It may be a little over kill in the summer but I don't care... the twins seem happy so they stay on :)
I had posted this in a thread in the Regal forum, but I see there's now discussion of closing that forum to those of us who don't own Regals. Hmmm.
Anyhoo, if you'd like to keep an eye on my boat with my Xtreme heaters with winter, here's the site:
(note: as of 11/13/07 I haven't even put the heaters on board yet...it's been really mild! Also, I've got OB's, so I don't really use the heaters for an engine room, but rather to keep my waste treatment system, my water system, and my cabin above freezing)
http://74.93.205.62/
