Wood Blinds
Britanic
Any suggestions on who makes them. I am looking for "boat friendly" meaning some way to hold the bottom in place. I currently have aluminum mini blinds and the bottoms are clipped in, its a pain to undo this every time I want to raise them. Boat is a Silverton 1988 34C
I would try Home Depot or Lowes. Explain to them what you need and they are actually pretty good at coming up with a custom made solution. You might have to modify them yourself for the bottoms but a visit to your local RV supply shop will give you some options.
You could contact Carver to find out who makes there's for the large Voyagers...but they are VERY expensive!
You can find all the name brand stuff that they carry in all the stores at americanblind.com. I've been using them for years and noboady can come close to their prices. I'm certain if you ask for something to hold them down, they will have it....
Try the "bottom up" kind. (I think that's what they are called.) Instead of pulling on the cord to open them, you pull on the cord to close them. Solves any issues with securing the bottoms.
You may want to get rid of the locks and use a heavier velcro type look/loop closure on the backside. You just tug slightly on bottom to release closure and then raise. If you use the loop side on the back of the blind vs the frame, it keeps it from rattlin against the window.
I have levilor wood Blinds in mine that were installed by the PO.
The wood base piece is heavy enough to keep them taught and I get no rattle under way.
The side windows were cut at an angle to fit the window. There, there is a single "L" bracket screwed to the bottom forward corner of the frame that the lower piece rests against so that it won't fall vertical.
I just replace my with Levilor also, got them from Lowes. I inquired about a side track blind. They had them as a option, but they wanted too much money for the and I passed. Many custom vans have them on the windows.
Magnets held on by double sticky tape. Wal-Mart house numbers department for the red tape. Get oval magnet for window sill and round magnet for blind that way you don't have to be too precise when sticking them together.
