Wow, that's cold...
Skeetobite
Snip from msnbc.com today:
In Minnesota, some took it as just another winter day, even in the state's extreme northwest corner where thermometers bottomed out at 38 degrees below zero at the town of Hallock and the National Weather Service said the wind chill was a shocking 58 below.
Just think about it, people up there actually wonder why we live in a hurricane zone.
Ken
Our house is 9 miles from Hallock, MN. Thank the good Lord it's SOUTH!!
So you guys must be filling your blocks with nearly full strength anti-freeze? What about the FWC boats? Do you increase the strength of your 50/50 antifreeze? If I remember correctly, 50/50 is good to 34 below?
Full strength antifreeze does not offer as much protection as properly diluted antifreeze. There is a point in the dilution of antifreeze called a "eutectic" where the freezing point is depressed well below the freezing point of either liquid.
I don't worry about no 38°F below 'cause I ain't gwine der.
Full strength antifreeze won't cool an engine as well as 1/2 strength, but it does have a lower freeze point than 1/2 strength.
70/30 is good to about -70. I will guarantee you that I will NEVER be anywhere to test that mixture. Pure water has the best cooling properties. Monitor FWC recommends a max of 30% antifreeze 70% water, UNLESS you need more protection from the cold. I have no intention of testing that out either.
Ken
It just got me thinking about that minus 38 degrees. I'd be concerned if I was FWC with a 50/50 antifreeze mix as is common here.
Current Weather Conditions:
Mount Washington, NH, United States
(KMWN) 44-16N 071-18W 1910M
Conditions at Jan 14, 2009 - 08:55 AM ESTJan 14, 2009 - 07:55 AM CSTJan 14, 2009 - 06:55 AM MSTJan 14, 2009 - 05:55 AM PSTJan 14, 2009 - 04:55 AM ASTJan 14, 2009 - 03:55 AM HST
2009.01.14 1355 UTC
Wind from the WNW (300 degrees) at 96 MPH (83 KT) gusting to 101 MPH (88 KT)
Visibility 1/8 mile(s)
Sky conditions mostly cloudy
Weather Blowing snow
Freezing fog
Temperature -22 F (-30 C)
Windchill -72 F (-58 C)
The weather in New Hampshire doesn't seem to be slowing Les down...
Les?
Les?
Les was last seen at his Bear Attracting Bird feeder in a frozen state with a bag of bird seed in his arms...He will be back in the spring when he Thaws out...
if it gets colder that your freeze point its ok it only turns to a soft slush nontox is the same way throw a cup in the freezer.... it does not get hard more like pink slush
I used to do that with booze to make daqueries or margaritas......
It's so cold that...
I saw a dog with its leg up - frozen to a fire hydrant.
the first time i went to minneapolis i needed to get from my hotel to a customer. since the 2nd story of the entire city is connected, i got myself a map, planned a route and set out early so i wouldn't be late. since i wasn't going outside, i didn't bother taking an overcoat. i got a block away from my customer's office with only a department store between me and my destination. of course the store was closed. i headed down to the ground level and ran for a block outside in something like -25 degree weather (with -50 including windchill). it took my body almost an hour to recover and some people say my brain never has. but, enough gray matter reamined that i always brought my coat with me after that.
I think I'll take our hurricanes. At least with them there is a slim chance of getting a direct hit & with a cat 1 or 2 storm I have a house that will suffer no damage at all. Yes we build em that well here.
With a hurricane I can usually see it coming & know that it will pass, one way or another, in a day or less. Bitter cold can be on top of you for weeks.
