Pettit makes Zinc Coat and sells it in an aerosol can. It is definitely better than just regular bottom paint when you put it on the running gear. From everything I have read, it is not as good as Prop Speed but much LESS expensive and much LESS labor intensive.
I use it as well as a number of boating friends.
There have been a number of threads about zinc paint you can buy at the paint store which people here claim is basically the same but much less expensive. The Pettit product is in the $25-30 range per can.
And no, it doesn't wear off quickly. I got 2 seasons out of an application with little loss of RPM's.
