Zodiac Inflatable Valves - Help !!
zolna
Does anyone know how to remove the spring-loaded inflation valves??...and if removed can you get direct access to the inside of the tubes??....due to a too long to explain accident I now have water (a lot) inside one of my main tubes.....see no other way to drain out..(yeah, I know I could puncture the bottom of the tube and drain it - not acceptable !!)...this is a large full center console so it cannot be turned over.....the only thing I have found out on the internet is a statement saying that a special tool is needed to reinstall valve core so as not to destroy valve......any info would be greatly appreciated....the Zodiac manual and Zodiac are of no help.....
listing badly in Illinois.......
I have a Zodiac, but smaller than yours. So please only take my advice if it makes sense for your model. I have removed the valve using needle nosed pliers. Be careful not to cut your diagram. There should be an (X) looking valve under the twist off valve cap.
Place each side of the pliers tips on each side of the valve. You will need to gently press though the sides of the diaphragm which should just fold in. Turn the valve and it should twist out. This is how I replaced one of my valves a couple of years ago. But as you stated you may need to obtain that special tool not to do dammage. The needle pliers worked for me, but your model may have a different valve.
Good Luck.
zolna, a few years ago I removed the valve by accident and I was able to reinstall it. The tip of the valve has to pass through the lower hole which is smaller than the valve tip. I used vaseline and was able to push it in and get to thread and it was good to go. To remove it leave the cap inplace and turn it counter-clockwise a few turns and it will remove the valve.
Lakeguy
Thanks Radiowaves.....but I think my valves are of a different kind....they are spring loaded and almost look like a larger version of a tire core valve......
Zolna, in the center of my main tube’s valves, I have a blue plastic tip that has a spring that presses the diagram down when turned allowing deflation. Although different it may be of a similar principle. But I am sure you will get more advice as the day goes on from RO’s with a model more like you have.
