I just did this install on my 3607AC last year. I'll give this a best shot at verbally describing since the boat is in storage (no pics - forgive the length).
Last winter had the canvas shop sew in a round boot on the underside of my canopy (like yours) adjacent to the canopy support sleeve. The boot has a circumferential zipper around 180 degrees with the end of the zipper positioned next to the support sleeve. I had them place an eyelet in the sleeve large enough to put a coax fitting through. Then I slid the antenna into the boot, closed the zipper snug up to the cable, ran the coax inside the support eyelet (exposes only 1" of coax to the eye), down the support rod (later covered with a wrap to hide it), ducking into the access hole next to the helm. From there I have a wiring access route down to the lower helm, ducking into the engine room, running diagonally across to the coax outlet. Works great!
