As signature, 1996 5.7 with TBI fuel system. This is a Pre-Vortec, flat tappet engine, 1440 hours. Yesterday, lost power, missing, never stalled. Till we approached home dock then it roughened up and quit. Thought it was ignition parts, installed plug wires, cap, rotor, decided to inspect sparkplugs. All four left/portside bank have water. Boat's in the water and I can't get onto the lift till tide rises. When I tried to crank it to blow the water out, just produces more. I think that's because the lower unit/raw water pump (Alpha) are still in the water.
Complete Sierra (former OSCO) exhaust less than a year old. Water appears even with the supply hose to the bottom of the manifold (drain fitting) disconnected. This suggests water is entering the cylinder(s?) from elsewhere, pretty much all four (1-3-5-7). Can't try a compression test till boat's on the lift or so it seems.
I'd heard VORTEC heads crack from time to time, Pre-VORTEC almost never.
Plan's to remove exhaust that side, get compression test, oil/pickle the cylinders as well as I can. Oddly, the Oil Filler area is not milky and the engine oil doesn't look milky...YET.
Any suggestions, recommendations?
