Oldfishboat's story about the high water alarm reminded me, here's a question - do you regularly check your bilge pump float switches?
I ask because I am now installing my third switch since January. The first replacement was for a switch that no longer worked. I replaced the old caged switch with a new Rule Super Switch. Three months later the "new" switch would no longer pivot - wherever you placed it it stayed, and no amount of water would raise it. If it did turn on it wouldn't turn off after the water was pumped out. Two months later and the second "new" switch, also a Rule Super Switch, is doing the same thing. This hasn't been a problem because my boat doesnt leak any detectable amount - the only water that tends to accumulate is from rains that blow in around the edges.
I only manged to catch these because I manually check the switches before every departure or as part of my weekly check if we don't go anywhere. Oh, and the next switch won't be a Rule Super Switch.
