Drain plug stuck!
ajjacobs
Trying to get my drain plug out and cant seem to get it to budge. Have some lube soaking in now but there is no rust or corrosion. I could go at it with a breaker bar for some leverage but do not want to strip the head. Any other ideas?
AJ
This is a garboard drain with the square head plug? Remove and replace the entire assembly...the collar is held in with three phillips-head screws and you can easily break the seal to remove. Cranking on the plug itself is a good way to loosen the collar and it will start leaking.
Drain Plug??? What drain plug?? Bottom of the boat, oil pan, hot water heater, engine block/manifold etc???
I would be careful as to how much torque you put on either of these plugs.. if bottom of the boat, would be careful not to rip the fixture out of the hull... fiberglass or otherwise.
Yes its the garboard drain with square head (should have made that clear). So I should just remove the assembly and replace? I am very concerned with leaks so I am a bit nervous removing the assembly. Any tips on replacing this? Thanks.
AJ
AJ
Remove. Lay a bead of 3M 4200 (or 5200,but will be harder to remove later if needed)around the seating area. Replace, tighten and clean up any displaced 4200 with a small screwdriver and smear around the joint.
Works like a charm. The garboard drain collar is one of those items you check once in awhile...
Thanks.
AJ
Give the penetrating oil some time.
Hit the head with a hammer a couple times to "shock" it a bit, it's a pipe thread so it should loosen up. Try the big breaker bar, probably need an 8 point socket though. Or give the 18" adjustable a try. If that fails replace the whole assembly, nothing to lose trying.......
Replace the whole thing. It shouldn't bind and even if you get the plug out, you may be setting yourself up for the same problem next year.
I never over tighten mine, but I do smear a bit of RTV on the threads each spring. Comes out easy in the fall and the RTV comes out in one piece. Take your pick: black, white, or clear
Always put some OMC triple guard grease on mine, comes right out even after 6 months in salt water. Works just as well on the engine/manifold drains.
I use teflon tape. Just need to be careful not to overtighten as you could crack the fitting.
That plug is the source of transom rot in many boats. The very first thing I do on a new boat is replace it. Most of the time it requires removal of a area of wet/rotten wood in the whole area. After through cleaning, I fill the void with thickened epoxy and install the brass tube type drain with rubber bottle stopper type plug.
Had similar problem many yeas ago. Once removed, I replaced with a brass plug with an octagon head that fits a standard SAE socket.
Sounds like it was too tight to begin with. I put some Teflon tape on mine, it removes easily.
I have the exact same problem. Boat is on a hoist with no trailer and it's very hard for me to get to the plug. I can crouch on the tanks to try and loosen it, but I would never be able to work on the collar. I've just left it stuck for 6 years. Maybe I should have the shop replace it at next service.
Well I joined the club here. Yesterday was not a good day for me. Oil change pump broke, and then the plug was not budging so I got some more leverage, and noticed the collar moved a hair. I do have a few questions on the topic.
1) Is the one with the backing plate better as it can pull together better?
2) I had one LONG screw (2+ inches) that I removed and the other 2 were 3/4" screws. When I went in the boat I found a nut obviously from the long screw, but also a thick green wire labeled 702 with a round connecter on the end. I am assuming that was connected to the screw as either a ground or for part of the corrosion system. Any idea what that is? I am looking at my maual now but no luck yet.
Any help would be great.
MJK
MJK,
I removed mine to re-bed it and reinstalled the same one due to the fact that I would have had to play Houdini to use a backing plate, almost impossible to reach. If I could have used a backer without a great deal of aggravation, I certainly would have.
I believe the green wire is your bonding wire. Here is a link to 14 pages in case you are bored :)
https://ir.library.oregonstate.edu/dspace/bitstream/1957/4829/1/SR+no.+622_ocr.pdf
Originally posted by Bayrat
MJK,
Thanks, I had nothing better to do tonight. That would make sense.
After a closer inspection, I don't think a backing plate is possible. There appears to be some fiberglass strands, around the hole, that I would probably not be able to get flat.
MJK
I had the same problem with a Tiara I just bought. Couldn't get it out. They stripped the square top to a round. Instead of replacing the whole assembly, I drilled holes all around next to the treads and broke it out. Don't get too close to the threads when drilling...Its worth the try, If that dont work then you can replace the whole thing.
