Two issues with ethanol in gas -- (1) compatibility with fuel system components on older boats, (2) water.
I posted a long analysis of the water issue. Basically, if your fuel source is sound and your system doesn't let water intrude then there should be no problem.
Compatibility is a bigger and costlier issue. And it's not just what's on your boat, it includes the whole supply chain. If it ran through an incompatible line or tank, then you may see problems that had nothing to do with your setup.
Recently, I have learned of a third problem - paranoid boat owners. In the last month I learned of three cases of "bad gas". After all was said and done it turned out it was the boat owner at fault - each had dumped all kinds of additives to try to prevent problems they weren't having, and ended up with problems. I saw one - brown goo separated and sank to he bottom. Turned out that after the fuel guy confronted him, the owner confessed he had added three different additives trying to make sure he wouldn't have problems (boat's on my same pier with me and we use the same gas). It ended up costing him about $2000.
According to two of the better fuel service folks in my area they say, take it as it comes out of the pump and run it. As long as your boat systems are compatible and sound, there should be little problem. According to them the recent experience has been that nervous boat owners are doing more to screw up their gas than anything they see from the supply side. Earlier reports of problems from fuel distribution have proven to be mostly owner induced problems.
Cobalt's gel problem has me intrigued. From everything I know it would suggest either a boat system incompatibility or fuel delivered through a distribution chain that had a compatibility problem. By now most of those should have been found and resolved.
Go easy on the additives - treat as you would for gas before ethanol.
