tied up in Oriental this afternoon. wasn't going to stop in Oriental, but there was a nasty line of thunderstorm approaching and north of us...
there is something going on at Haulover/ICW in Miami... It is a known trouble spot due to shoaling but it's never been that bad. 3 weeks ago, I made it thru just fine, showing 10' depth. that same day at low tide, I dinged the stbd prop while showing 10' on the sounder (on the port side of the boat) and while on centerline. so whatever it is, there is something very hard and very vertical, near centerline (the channel is marked by 3 floating buoys). It was a minor ding. An AZmut that was following us, also hit.
when heading north, last tuesday, at rising mid tide, i stayed on the green side bumping stbd in and out of gear and with port engine in neutral. despite that we hit both props. didnt insist or even tried to reverese, I called Seatow, they pulled us out and towed us thru on a path litteraly against the green buoy. The guy said they pull 5 to 6 boats a day there and that you have to be almost outside the green side to find a narrow stretch of deeper water.
bottom line, the temp buoys are off and if you draw over 4 to 5', stay outside! I suspect the green is offset a little so that boats dont' pass too close to all the swimmers and boats beached on the sandbar...
despite the fact that port was not even in gear, that prop took a beating from being pulled out and one blade is missing a chunk of the tip. Beyond the capabilites of the shop in beaufort. The yard had a set of reconditioned prop, almost the right size 32x42 instead of 34x41. We lost about 1kt at cruise and need to turn 1950 to get 20kts cruise, but on the same fuel burn.
I'll try SSprop, thks for the tip, or see if there is a shop in newport to fix them... if not, Jarrett told me that Jimmy and Frank prop in FLL does miracles...
While on the hard, I removed the defective transom light (abyss) and had the yard drill a 3" hole in the spacer to coil some wiring that can extend to the swimplatform to replace the light in water.
In order to make it here on monday morning and minimize delays, i had to run some long days... longest run was Georgetown to beaufort, 175NM in 23 hours. it was hard to stay awake, the expresso machine up on the bridge came in handy!
I ran about 25 or 30 hours at night on this trip, it's actaully pretty nice. no traffic, and the markers are easy to pick. With no traffic, I can use the spotlight without worrying about blinding others... plus since you can't read the water, you dont' need to see it!
In fact, i prefer running at night with a good tide, than during the day and low tides.
speaking of reading the water, Little River Inlet is the worst spot on the ICW this year. George, didn't you have problems there in the fall? On the south of the inlet/ICW intersection, I had no trouble finding 10' two hours after low tide. Once we reached the north side, the bottom came up and there is a bar across the channel, extending from the floating reds towards shore. I tried poking the bow 3 times, 25 to 125' from the red and coudlnt' find water. each time bottom came up to 7' and i backed out. I was creeping so i could back up on the spot. I decided to take a look close to shore, on the unmarked green side and found about 10' of water. Not much fun doing this at 1 in the morning but frankly since you can't see what's in that murky water, i doesn't really matter.
unfortunately, the tides aren't that big there so you dont get the 6 to 7' extra you get in GA. So, anyone who's going to go inside this year, time Little River for high tide and take it slow, favor the shore, north of the inlet channel.
the rest was fine, I had read reports of trouble north of the Onslow bridge, by Bear and Browns, but never found less than 9' there.
as to running outside, we did on thrusday, 3 to 4, that was fine. anything more than that on the beam or quarter and it's a miserable ride for the crew and the boat. We do have a lot of weight up here, enclosed skylouge, large tender and PWC and it doesn't help.
I talked to the captain of an 80' Hatt at the yard, who was also in to repair props dinged down in Miami, and he ran outside but he's stabilized. Said they had 6 to 8 most the time... cant' do that without stabs.
here is GE shot of our track thru New River Inlet... the yellow lines to the rigth are GPS fix bugs where the track briefly jumped, actually, I dont' suspect it's a GPS issue but a GOOPS issue.
