Inflatable PFD problems
chc
I'm curious about the reports of premature jacket inflation on some of the "automatic" inflatable PFD's due to humidity, sweat, or rain. has anyone experienced this sort of thing? I know Mustang, for one, has a switch built in that requires it to be under water to trigger, but I don't know if that is a marketing thing or is based on actual problems. Any thoughts?
Chc,
The hydostatic PFD is just a different type of trigger. So rain wont trigger it . I have both hydrostatic ( must be submerged ) and the disolving tablet thing. Ive never had a premature inflation. The hydostatic ( mustang ) is almost a year old. The other type is like 4 years old. I should change the arming mech . I havent so I am sure I am at risk. Its part of the maintenance.
I changed the mechanism after one inflated in a locker from humidity.
We just purchased a couple of mustang hydrostatic PFDs last week at the boat show. The sales rep did mention there have been reports of the automatic vests inflating accidentally, but he suggested this was rare and had mainly happened on open sailboats where the crews were getting drenched. The hydrostatic PFDs, as Rob mentioned, must be submerged (water pressure) to inflate. As well the rep told us the arming mechanism in the hydrostatic vests require maintenance every 5 years, while the regular automatic vests neeeded it every 2-3 years. But while the hydrostatic needs less frequent rearming, the rearm kit is more expensive than that needed by the auto vests.
Terry
Not to change the topic but has anyone ever inflated one of these in the water. They encourage u do it once so u know what to expect ?
The most trouble free type of inflator for these devices is the Halkey-Roberts inflator - generally uses a 33 to 50 gram C)2 cartridge, little green plastic 'ready' tab that breaks off when you pull the cord, attached to a lever that punctures the cylinder seal.
I use the belt pack type when I'm on any boat outside of work, kayaking, fishing, working (moonlighting), whatever. If you're using one of these devices, you really, really do need to try it out in the water - when it inflates, it feels like you're holding a float from underneath. Best way I can think of to describe it. Almost feels like it's pushing you backwards into the water until you get it over your head.
The regular inflatable PFD's provide significantly more buoyancy than a comparable foam type III or V, or the blocky type II's. I believe they have only slightly more buoyancy than a Type I, but I could be wrong. Could be way more. Problem is, foam is always buoyant, inflatables are only buoyant if the cylinder is intact, the inflator is intact and capable of opening the cylinder, and the bladdder is intact and capable of holding the pressure. No intrinisic buoyancy at all.
Now, I'm not knocking them. I use one of the 'sketchier' types of inflatable myself, and I have a more than passive knowledge about the factors influencing a person in the water's survival. But you do need to maintain these things. And that's the biggest doubt I have with the automatic models - are they really being maintained? If the bobbin degrades for whatever reason, will you really replace it every year or two? IS it REALLY going to automatically inflate? Did you repack it right? (Yeah, it MATTERS) Use the right size cylinder (different makes and models use different sizes)? Did it inadvertently fire when those darned green tabs inevitably broke off and you 'meant to rearm it but never got around to it'?
Compared to, is it made of foam? Is it there? Then it floats.
Just food for thought. Like I said, I'm not knocking them, just encouraging a little due diligence.
Just reread the first line of the original post.
Fortunately, no, I've never had an issue with premature jacketinflation.
I have a Stearns Inflatible PFD purchased through the CG Auxiliary. I did a test with it and I recommend everyone who uses one to do the same. I jumped into 25 ft of water while wearing. it. I was taken aback by how fast it inflated and shot me to the surface! I found that it was very difficult to swim in it at first. It had too much inflation around my shoulders which restricted my arms so I could not swim except on my back. I released a bit of the air which solved the problem.
I'm really glad I have mine and frequently use it. It has never inflated accidentally.
Do not leave them lay in your tender over night I was told, I live in the PNW- can get wet and they will go off. My friend has had two inflate on him , never while wearing- it has been from leaving them out.
Thanks for all the input. We'll be running some tests this Spring; I've often wondered how they would be when they inflated. Interestingly enough, of the 120 boats in our marina, I doubt that more than 3 crews actually wear PFDs while on the boats. High hopes?
I have a Mustang 3083. Its about 4 years old now. Every time I go on the boat one of the 1st things I do is check the bobbin and cylinder. Then I put it on and basically forget about it until the end of my trip. Every fourth or fifth trip I manually inflate it before I leave for the night to be sure its still full in the morning. Would suck to find a leak.
Ken
5 years with bobbin inflators and not a single problem.
Ken, I like your suggestion to manually inflate and check for leaks! Can that be done with the canister still armed? Or does it have to be rearmed? On mine the cannister can't be used once it is removed. It must be replaced.
