- Sep 16, 2003
- 12212
- 12,213
4'2" shoudl be easy...
there is a lot of "noise" made about the ICW but it's really not as bad as it seems. Pay attention, stick to the middle of the channel when possible, dont' take shortcuts and watch the sounder.
from my notes...
-the entry to the ICW northbound in Charleston harbor was a little shallower than expected but we still found 8'MLW...
Here are my notes on Shallote and Lockwoods folly:
We got to Shallotte just past low tide (45' past Low) and this is what we found on center except otherwise noted:
17' at 82
12' 100yards so of 81
12' at 81
17'' North of 81
19' at 80
17' at 78
20' at 77
13' at 76, about 30' from 76
13' at 75, about 5' from 75
We hit Lockwoods Folly 1:45 past low tide and here is what we found
12' south of 48
11' at 47A and 47
16' north 47
18' from 46 to 41
11' just south of 36
17' at 33
Again all on center. USCG Blackberry was repositioning one of the reds.
-Cape Fear River to Snows Cut: stay in the channel and you'll be fine, pleny of water there despite reports of grounding.
- New River/ICW was dredged earlier and not an issue
- Northern end of Alligator river: i dont' know what the fuss is all about with guys running aground there... jsut follow the markers (some charts and plotters are outdated at FL G 3 has been moved) but if you follow the markers, there is plenty of water. non issue
the key is really to stay in the center when you get to "trouble" spots like inlet crossings and slow down in those areas. When i get to 3 to 4' water UNDER the boat, i am usually at idle. under 2' of clerance and i bump in and out of gear, one engine at a time...
going slow also lets you feel the bottom... for instance when it gets a little shallow you can alter course a little and see what happens to your depths. if it shallows more, then you know that the deeper water will be on the other side. if you just plow thru a 10kts+, you'll be aground before you know it.
you also have the rockpile up in Myrtle beach but again stick to the middle and it's no big deal. unless of course you have to cross a barge... but there is very little commercial traffic. we rarely encountered more than one barge a day last month.
from my notes...
17' at 82
12' at 81
17'' North of 81
19' at 80
17' at 78
20' at 77
12' south of 48
11' at 47A and 47
16' north 47
18' from 46 to 41
17' at 33
