My Deviant Compass
possible someone messed with the adjustments in the past. It isn’t hard to swing the compass but if you are still suspicious of a location problem I would remove it from the boat and see what's up. A first adjustment on your comfortable kitchen table will be easier and then the second can be done on the boat. Instructions can be found in many places, Bowditch probably has it. Here is one link.
http://terrax.org/geography/compass/compass.aspx
One thing I was thinking, is that I bring down my hand bearing compass to Jack's boat. First, with the compass away from the electrical stuff, get a heading. Then, move it slowly in towards the boat's compass, on the same line, and see if it starts to move. Once touching the boat on the compass, if my bearing compass hasn't moved, I would imagine it's an issue with the compass and not magnetic interference.
Simple test, but it certainly should be informative.
Steve- that sounds like another 3 beer test! Good idea. That can be followed by Bruce's suggestion. Make the first adjustments off the boat.
Jack
"Where do you get/find/locate the plastic screwdriver?" -- RWS
Radio Shaft, Home Desperate, Lousie's, any electrical supply house.
You can also whittle down a wooden or plastic popsicle stick and you get to eat the popsicle!
For the screwdriver, I've always just broken the tip off a pencil and pushed and turned with it. The screws in the BIC's turn easily.
While rumaging around the internet I found the "Handbook of Magnetic Compass Adjustment", from the National Geospatial Intelligence Agency
You can download it HERE
... everything you always wanted to know about deviant compass' but knew you should not ask!
Go to ypour local hardware and get a 8-32 x 2" or 10 x 32 x 2" brass screw for 25 cents. File end down to make a screwdriver tip.
Steve G and I took his bearing compass for a ride today. We made some rather interesting discoveries.. Bearing compass was dead nuts with Magnetic heading on GPS. Boat compass was "AFU" (that's a technical term). What we found out was the compass card was actually bumping up against one of the 2 alignment pins(?) and actually getting jammed. When you bounce a little from boat wakes it frees up momentarily and then gets jammed up again. The compass card is not completely free to move.
Time to pull it out and take it to Richie!
Needless to say when you're out in the ocean with constant bouncing, who knows what that thing would be indicating.
Steve- Thanks again for your help today.
Jack
It's the 45 degree lubber lines that it's rubbing. The left one, for some reason, is bent inwards toward the card, whereas the right one is bent outward toward the glass. We're pretty sure the left one is rubbing. You could see it not even move.
Your compass is DONE, dude. Will no longer keep your courses within due bounds. See if you can replace it under warranty - should be able to, since it sounds like it may have jumped off the pivot (yup, somebody was reading the latest on this thread shortly before having his compass swung. Write - not call, but write, to Ritchie).
Seeing the latest couple posts, looks like he may have been right! Just wish he could have knocked off that last little 2E on NE. I run LOTS of northeasterly courses.
