Trying to answer some of your questions- yes, I do have Chapmans (I should use it more than I do).
Only equipment is my Chartplotter, that is set to display COG (magnetic)- no autopilot, and my boat compass.
The closest speaker is at least 4' horiz. distance and 3' below compass plane on dashboard. So I don't believe the speakers are any influence.
I was observing these differences while in the (Merrimack)river, at places where it's fairly wide with minimal effect of wind or current. If you assume for the moment, that there is no wind/current effect, the GPS(chartplotter) COG (magnetic)= (compass course to steer[actual compass reading])+ (compass deviation). For a given COG if deviation was 0*, COG(M)= CTS(M)
If you assume a 3* error, over a 10 nm leg, that would give you a 0.5 nm cross track error.
I would imagine the compass really needs to be properly aligned (Lubbers Line) first, before any sort of deviation table is prepared.
SteveG- sounds like a plan. The deviant owner is already factored in
Again, some great feedback folks!
Jack
Jack
